TPMS light 2020 tundra
Discussion in 'Wheels & Tires' started by Rockanock, Dec 11, 2023.
  1. Dec 11, 2023 at 1:39 PM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    2020 tundra double cab 2wd tire pressure light came on. Took it to the tire shop today and they found a bad tpms sensor and replaced it. They then tested all the sensors and they are all reading good. My light is still staying on. All tires are at the correct pressure. I called my local Toyota dealer and they told me sometimes it just takes a while for it to go off. I have disconnected the battery and let it sit to see if that reset anything. It did not. I also drove around for a while at speeds above 25 mph. I also tried pushing the reset button. When I go to the screen to read the pressure none of the tire pressures are displayed and there is a message that says tire pressure recalibrating, please wait until complete.
    Any help would be appreciated. Thank you.
  2. Dec 11, 2023 at 3:43 PM
    Turn the ignition on but do not start the truck. Push the button 3 times so that the light starts flashing. Let it flash until it goes solid. Let it sit for another minute or so and then shut the truck off. Start it and start driving. You do not have to push the button. It may take a drive or two but the pressures should start popping up. It is aggravating for sure. I've had my share of it with my 2020.
  3. Dec 11, 2023 at 5:52 PM
    Rockanock
    Thank you very much for the response. I’ll give it a go. The tire shop told me for whatever reasons Toyota and Lexus seem to have this issue more than any others.
    NoMoreGreen likes this.
  4. Dec 13, 2023 at 6:49 PM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    Any luck?
    tarathetundra likes this.
  5. Jan 6, 2024 at 6:44 PM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    Second that any luck, had my sensors replaced with new tires on truck picked em up fine then I threw my old wheels and tires in to take home then my TPMs went off I think the truck was confused on what sensor were what. I thought the reset was a hold not three press?
