Toytec Shackle & TRD Dual Exhaust
Discussion in 'Suspension' started by BlackSheep, Feb 28, 2019.
  1. Feb 28, 2019 at 4:45 AM
    BlackSheep
    BlackSheep [OP] ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    There's a disclaimer note on Toytec's site that says installation of their shackles requires modifications to the TRD dual exhaust. Is this true or just a CYA thing they tell customers about?
    And follow-up question if I may, does anyone have experience with their AAL option offered with the BOSS kit instead of the shackle? I used an AAL on my Jeep years ago, and the rear was still pretty saggy, and I ended up adding a shackle to correct it. I've been leery of using them again because of that, but I'm not sure if that apprehension is warranted. My jeep's rear was saggy before adding the AAL, and my Tundra's is not. So maybe it would be fine?...
  2. Feb 28, 2019 at 5:13 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Look how close your trd tip is to the stock shackles. The toytec is considerably wider
  3. Feb 28, 2019 at 5:35 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    It isnt the width of the shackle, it is that it brings the leafs closer to the tailpipes. I have no jssues with the toytec's set at 1.5" and the trd duals. Even on the lift at discount tire and the axle at full droop there is clearance, not issuse's offroad for me either.
  4. Feb 28, 2019 at 5:43 AM
  5. Feb 28, 2019 at 7:27 AM
    BlackSheep
    Scott
    Kansas City, MO
    This makes sense. With the shackle, the exhaust is raised up along with the body of the truck, but the leafs remain in same place, so the exhaust ends up closer to the leafs.
  6. Feb 28, 2019 at 7:35 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    We have seen the leaf pack get pushed down onto the TRD Exhaust. There has only been a couple cases... IF it happens, simply heat/ bend the exhaust hanger a little bit to help push the pipe down a tad bit more.
    badfishgood likes this.
