Toytec Procomp or Toytec Boss coilovers
Discussion in 'Suspension' started by 15max, Jul 10, 2015.
  1. Jul 10, 2015 at 12:00 PM
    15max
    15max [OP] New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
  2. Jul 10, 2015 at 12:02 PM
    Sweet_nasty87
    Sweet_nasty87 New Member
    Ala
    2015 White Tundra CrewMax 4x4
    ProComp stage 1 7in lift, xtreme mt2 35x12.5r20,
    All you get is 3 inches?
  3. Jul 10, 2015 at 12:03 PM
    15max
    Cole
    15 SR5 TSS 4x
    What do you mean, Ala?
  4. Jul 10, 2015 at 12:05 PM
    Sweet_nasty87
    Ala
    lol, name is Alan idk why it cuts the "n" anyways, im asking if 3 in is the most lift these setups give you. i always got told i should go to coilovers from my current lift as it would be so much better but no one told me my lift would be cut by more than half
  5. Jul 10, 2015 at 12:14 PM
    15max
    Cole
    15 SR5 TSS 4x
    There are coilovers specifically for a truck with a 6" lift. It's just not these lol
  6. Jul 10, 2015 at 12:15 PM
    Sweet_nasty87
    Ala
    cant find any on toytect thats why i wondered
    15max[QUOTED][OP] likes this.
  7. Jul 10, 2015 at 1:18 PM
    Thats what she said.
    JROCK915 likes this.
  8. Jul 10, 2015 at 1:18 PM
    I have the Toytec coil-overs and LOVE them!
    I can always get ahold of my Toytec contacts and ask them something for you if there are any specific questions.
  9. Jul 10, 2015 at 4:57 PM
    15max
    Cole
    15 SR5 TSS 4x
    Do you have the boss or the procomp. Both say Toytec. With the 3" strut spacers, it measures 24 3/4" from center of hub to bottom of the fender. What's it measure with the coilovers with them maxed out, do you know?
  10. Jul 10, 2015 at 6:28 PM
    BOSS...check my build...
    I believe the max is 4"
  11. Jul 11, 2015 at 10:26 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Toytec doesn't sell procomp stuff
  12. Jul 12, 2015 at 1:36 PM
    15max
    Cole
    15 SR5 TSS 4x
  13. Jul 12, 2015 at 9:00 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh, can't argue that^ but I would never run anything that says pro comp on it. U GET What U Pay for.
  14. Jul 12, 2015 at 9:27 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    The ProComp ProRunner front struts are really just a Bilstein 5100 with slightly different valving and a procomp sticker on them. I've heard from several places that Bilstein makes them for Procomp
  15. Jul 12, 2015 at 9:36 PM
    Sweet_nasty87
    Ala
    Idk why people bash on procomp...I have a 7 in stage 1 lift from them and I don't k ow why people say it rides rough. My buddy has similar setup with coilovers and it's about the same
  16. Jul 13, 2015 at 8:08 AM
    15max
    Cole
    15 SR5 TSS 4x
    Hmm, so many mixed reviews! lol So far i'm leaning towards the toytec boss because someone has said that you can get 4" out of them. If that's the case i'll max them out for 4" of lift, diff drop and UCA's and call the front good.
    Any input on that plan of action?
  17. Jul 13, 2015 at 8:31 AM
    csuviper
    Broomfield, CO
  18. Jul 13, 2015 at 8:33 AM
    15max
    Cole
    15 SR5 TSS 4x
    It wasn't my intention to come across as an a-hole. I hope you didn't take it that way. I'm just trying to figure out what the best, most affordable front coilover is.
  19. Jul 13, 2015 at 8:35 AM
    csuviper
    Broomfield, CO
    No i didn't take it that way at all. Just didn't think Toytec sold any Procomp stuff. I was pretty certain of that but i was wrong. Makes sense as Relentless stated that they are just Bilstein shocks.
  20. Jul 13, 2015 at 8:38 AM
    15max
    Cole
    15 SR5 TSS 4x
    Do you know the validity of if the boss coilovers can indeed go up to 4" of lift? Also, would 4" be okay without a drop bracket if I do a diff drop and UCA's? (2015 4x4)
  21. Jul 13, 2015 at 10:21 AM
    Pretty sure you can, but to be sure I would just give @ToyTec Lifts a call...303.255.4959.
  22. Jul 13, 2015 at 12:03 PM
    15max
    Cole
    15 SR5 TSS 4x
    Thank you for that Sean. I gave them a ring. So for future reference for everyone here that want's about 4" of lift in the front, without needing a front drop bracket... ToyTec Boss Coilovers (set for 3.75" of lift or, max 4" of lift), Diff drop (necessary to accommodate proper CV angles for the additional 1" of lift over 3" lift) and two option for UCA's (necessary to achieve proper alignment specifications)... either Total Chaos UCA's which are more rugged and designed for off roading or Light Racing UCA's which still work to get the alignment in spec but aren't quite as rugged as the Total Chaos UCA's.
  23. Jul 13, 2015 at 1:51 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Camburg has nice uca's also that's what I have on mine.
