Toytec pro comp replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by ODSteve, Aug 22, 2014.
  1. Aug 22, 2014 at 11:01 AM
    ODSteve
    ODSteve [OP] New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    uploadfromtaptalk1408730486290.jpghas anyone heard of this or seen it or have a link so I can see it?
  2. Aug 22, 2014 at 11:37 AM
    ODSteve
    Steven
    Nevermind i just got off the phone with them and there gonna upgrade me to ther boss suspension. Here is the before and after pictures of the lift.
    1795284_802063519833277_5550058623651481043_o.jpg 10571983_802063669833262_1153194255332270069_o.jpg 10549099_789570284427356_8295014510682283330_o.jpg
    T-Rex266 and TruckyTruck like this.
  3. Aug 22, 2014 at 12:37 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Where can we find out more about the boss suspension?
    ODSteve[OP] likes this.
  4. Aug 22, 2014 at 1:43 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Assume that it is similar to the 2000-2006 Tundra suspension: http://toyteclifts.3dcartstores.com/BOSS-Suspension-System-for-2000-2006-Tundra_p_1140.html
    TTBT2000
    Toytec BOSS Suspension System
    Fits All 2000 to 2006 Tundra 4WD and 2WD
    Designed for the best overall ride comfort and performance in mind, this complete lift kit is the best lift on the market.
    Includes:
    ----- TTFCST200 - ToyTec’s new BOSS front coilover is designed with a larger 5/8” Nitro steel shock shaft which is much more corrosion resistant than chrome plating and is valved specific to your vehicle. This improves overall handling and performance. The threaded Clear-Blue Chromate zinc plated steel shock body is adjustable from 0-3” of front lift height and can be fine tuned to level your truck side to side and front to back. They have a 200 psi gas charge and each shock is dyno’d before it is shipped.
    Upper mounts and adjustment rings are machined from 6061-T6 Billet aluminum and are then anodized black to prevent corrosion. Long handled TIG welded spanner wrenches are included for easy adjustment. We only use Eibach springs for our coilovers which means you have the best name and quality in the business supporting your vehicle. Comes fully assembled and ready to bolt on. All parts are 100% made in the U.S.A.
    Adjustable from 0-3.5” of front lift.
    650 lb/in Eibach (Red or Silver) coils handle additional weight well
    -----TAC-DR - When installing a lift on the front of a 4wd Tundra, the angles of the front CV axles will increase the higher you lift it. At 3 inches of lift, the CV joints will operate at considerable angle which will increase wear on the CV joints and the rubber boots. The front differential drop kit will reduce the angle placed on the CV axles thereby reducing wear on those components.
    Choose Rear Lift Options Below:
    - Toytec 2” lift rear Add-A-Leafs. This long style AAL offers a great ride and has anti-friction pads already installed. Comes with (2) new center bolts.
    - 1.5” rear lift blocks with zinc plated heavy duty 9/16” U-bolts
    (2) *New extended length Toytec Boss series rear shocks
    T-Rex266, TruckyTruck and ODSteve[OP] like this.
  5. Aug 22, 2014 at 2:56 PM
    ODSteve
    Steven
    I'm pretty sure he is right they are just now building it but it's beefier then the other one as he said haha!
    TruckyTruck[QUOTED] likes this.
  6. Aug 22, 2014 at 3:02 PM
    ODSteve
    Steven
    The pictures came from there Facebook page they said it will be another week or two for the boss
    TruckyTruck likes this.
  7. Aug 23, 2014 at 2:53 PM
    Ya I'm looking at their boss for the 4" lift
  8. Aug 23, 2014 at 3:30 PM
    TruckyTruck
    Gary
    So it's a 4 inch coilover lift kit? Guess I'll hold off on the fat bobs coilovers.
  9. Aug 23, 2014 at 3:52 PM
    According to Miles at Toytec-yep.
  10. Aug 23, 2014 at 3:55 PM
    TruckyTruck
    Gary
    Nice. Can't wait to get the details.
  11. Aug 26, 2014 at 1:02 AM
    TruckyTruck
    Gary
    Hurry up!!!!
    T-Rex266 likes this.
  12. Aug 26, 2014 at 10:28 AM
    ODSteve
    Steven
    I know I can't wait
  13. Aug 28, 2014 at 8:38 PM
    TruckyTruck
    Gary
    Sean, what else did Miles tell you about the boss shocks? Shock diameter? Spring rate? Price? If nothing, it's ok. Lift money is burning a hole in my pocket. I was pretty sure I would go with fat bobs and light racing uca's. 900 bucks... Hard to beat. I've got shackles and new poly bushings for the rear waiting.
  14. Aug 28, 2014 at 8:40 PM
    Will email him
  15. Aug 28, 2014 at 9:41 PM
    ODSteve
    Steven
    Yes do tell more =)
  16. Aug 29, 2014 at 7:55 AM
    "It is a 2.0 shock with a 700lb coil. I think we should be getting them today actually. Not sure about a set price yet, however it should be pretty close to our Ultimate kit."
  17. Aug 29, 2014 at 2:41 PM
    ODSteve
    Steven
    Nice and I like the red if I'm looking at the right one.. If so gonna get the red letter tires too haga
  18. Aug 29, 2014 at 2:54 PM
  19. Aug 29, 2014 at 3:17 PM
    ODSteve
    Steven
    Will be on the way soon!
  20. Aug 29, 2014 at 3:46 PM
    TruckyTruck
    Gary
    700 pound springs Is what I am looking for...
    thanks Sean!
