Toytec Lift
Discussion in 'Suspension' started by Hope38, May 20, 2019.
  1. May 20, 2019 at 9:09 PM
    Hope38
    Hope38 [OP] New Member
    Owen
    2007 Black Tundra TRD
    So I was looking at getting the ToyTec complete BOSS suspension system for my 2007 tundra. I want the full 3 inch lift, but I’m a little stumped for the options on the rear lift. I can either do a 1 inch block, 1.5 inch block, or adjustable 1-1.5 inch shackle. I’m not sure what would be better, and I also want to keep the rear level with the front. Any suggestions?
  2. May 20, 2019 at 9:48 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Toytec adjustable shackles. Better ride than blocks.
  3. May 20, 2019 at 9:50 PM
    GNTundra
    Gino
    2013 White
    This! :thumbsup:
    jewsNbrews likes this.
  4. May 20, 2019 at 9:50 PM
    reno_tundra
    reno_tundra New Member
    2019 White Tundra CM SR5
    From what I’ve read the shackle is the best way to go for the rear, and the 1” setting on the shackle should keep you level with 3” up front.
    There are also tons of write ups on this setup (I know because I’ve been wanting/researching it for a while). I know @T-Rex266 has this lift too so he might have some more info for you
  5. May 21, 2019 at 1:35 AM
    Hope38
    Owen
    Thanks man. I’ve got a leveling kit on it already but it’s stock suspension with almost 180K miles on it figured I could get a better ride while adding a little extra height as well.
  6. May 21, 2019 at 5:27 AM
    reno_tundra
    Yea definitely! That lift is valved for the tundra and I’ve never heard a “con” about it so i’m sure you’ll be very happy with it!
  7. May 21, 2019 at 5:55 PM
    Hope38
    Owen
    Sweet lol there better not be any cons for that much money
  8. May 21, 2019 at 6:49 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I did that setup and always looked to me that the rear was lower than front. Need to lift the rear and/or lower front. All trucks are different though. Good luck.
  9. May 21, 2019 at 6:52 PM
  10. May 23, 2019 at 9:34 PM
    reno_tundra
    also, post pics when you get it done!!!
  11. May 23, 2019 at 10:08 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    Shackles. 100%, ive been running them for a year. Just switched to boss in all 4 corners. Feels good!
    T-Rex266 likes this.
