toytec coilovers question
Discussion in 'Suspension' started by chance03, Mar 15, 2025.
  1. Mar 15, 2025 at 11:49 AM
    chance03
    chance03 [OP] New Member
    Hello, I just picked up a set of toytec TTLK25TUN c700x16x3 aluma coilovers, 2-3" lift. I have a Factory stock 2019 Trd Sport. my question is can i just swap these in on their own? do i need new UCA's? is this something i can do in my driveway or will i need specialty tools? Will this look weird without any lift in the rear? Thanks
  2. Mar 31, 2025 at 6:53 AM
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    With the 2-3" kit and 700lb springs, you may find that even at the lowest height adjustment they are still too high in the front for a "level" appearance (with no lift in the rear).
  3. Mar 31, 2025 at 7:18 AM
    Im actually suprised that you even got anything delivered from them. I currently have that setup until I rip it all out in a few weeks. To sit level with that setup, you will need a 2 inch lift in the rear. You will also need brake line extension brackets for the rear. If you are not familiar with suspension, I would not do it yourself. You can follow the instructions, but there are things that you can do to make it easier, such as loosening the lower control arm cam bolts to allow it to drop lower to get the stock coil out and the new one in. Obviously you will need an alignment immediately after. As far as the UCA's, a 3 inch lift is about the max with a factory UCA. Most of us replace them to have more adjustments to get a correct alignment.
  4. Mar 31, 2025 at 9:40 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think the TRD Sport is 1” lower than the standard stock suspension. So it’ll probably lift it 3-4”.
  5. Mar 31, 2025 at 9:59 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    If you adjust it down to 2” of lift you won’t NEED UCAs but you will WANT them and may as well do them while you are in there.
    Anything higher than 2” you will need them.
    JBA UCAs are the way to go.
    Easy install in the driveway no need for any special tools.
    You’ll likely find you will want some height in the rear as well.
    Coachbuilder Shackles are the way to go. How high is up to your preference.
