Toytec Bushing issue? *Video/Pics* SOLVED
Discussion in 'Suspension' started by badmotofing3r, May 21, 2022.
  1. May 21, 2022 at 5:37 PM
    badmotofing3r
    badmotofing3r [OP] To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Decided to crank the ol’ 2.0’s up a little and noticed this on the passenger side. I’ve been nice to these coilovers! My truck is basically a pavement queen besides a couple to three times a year.
    These coilovers are about a year and a half old. Do you think Toytec will warranty this?
    I notice no issue while driving. Tomorrow I was planning one of my rare off road trips to the mountains. Should I postpone? Thanks fellas.
    https://youtube.com/shorts/9LPK0wUk5F4?feature=share
  2. May 21, 2022 at 5:39 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No way would I sweat that enough to postpone.
    badmotofing3r[OP] likes this.
  3. May 21, 2022 at 6:25 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I don't even think there should be any play in that area...
  4. May 21, 2022 at 6:47 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    The driver side moves similarly but not AS much as this side.
  5. May 22, 2022 at 4:49 AM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Drivers side (good)
    Passenger side (bad)
    It almost looks like a dust seal or something?
  6. May 22, 2022 at 5:23 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  7. May 22, 2022 at 6:30 PM
    Vizsla
    Vizsla pretend2send
    It’s a dust seal, or more likely to dampen noise when the shock wiggles back and forth in the mount as the coilover cycles. There will be a shock bearing(uniball with misalignment spacers) in the middle of the upper shock mount. No worries, pretty common on that style shock and can make noise till fixed.
    Toytec Lifts and joonbug like this.
  8. May 22, 2022 at 6:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And you really need to clean the threads before trying to adjust them. Get one grain of sand in there and they will no longer be adjustable coilovers.
    Toytec Lifts likes this.
  9. May 22, 2022 at 6:46 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Don't worry I spray them down with Free-All real well before turning them.
  10. May 23, 2022 at 1:16 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    100% accurate. Its just a little o ring to help assist in keeping contaminates out of the heim. You can leave them, cut them out, or push them back in. Either way, DM me your order number and Ill mail out a replacement set of O-rings for you. No need to worry :)
    BTW clean your coilovers before doing adjustments. The aluminum adjuster ring does not like junk building up on the threads, causes quite the headache.
  11. May 23, 2022 at 5:22 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Thanks for the reply, Toytec! Just to be clear, I did not turn the collars when they were this dirty. I'll send you my information. Thanks again.
  12. May 29, 2023 at 8:28 PM
    Dooders
    Dooders New Member
    D
    2014 MGM Dbl cab SR5 TSS
    mine are doing the exact same thing are are becoming noisy. What’s the best way to clean and fix?
  13. May 29, 2023 at 11:04 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Not too sure. I messaged Toytec back then and never heard from them. Been running like this ever since and haven’t had an issue yet…
    Dooders[QUOTED] likes this.
