Toytec Boss
Discussion in 'Suspension' started by N8Dizzle, Jan 29, 2016.
  1. Jan 29, 2016 at 7:31 PM
    N8Dizzle
    N8Dizzle [OP] New Member
    Nate
    Seattle
    2016 Magnetic Gray Tundra Platinum
    Toytec Boss Lift w/AAL, TC UCA's, Fuel Trophy D552, 305/70R18,Cooper STT Pro Tires,Interior/Cargo LED's, 10% Window Tint, Hypertech Speedo Calibrator, anytime fogs, WeatherTech Digital Fit Mats
    I've only had my kit for a month or so and the ride is great but it's already starting to rust on the top of the coil over shock. The rear shocks are fine. Is this being noticed by anyone else with the Boss kit / Is it normal for something this new?image.jpg
  2. Jan 29, 2016 at 8:00 PM
    Normal. You live in Seattle. "Rust Never Sleeps". I know. I lived south of Eugene, OR for 14 years. Trucks become rust buckets eventually no matter what you do in the Pac Northwest, unless garaged with climate control or cleaned weekly top to bottom/underneath. Surface rust in high humidity climes can take place in hours. Literally. Leave a non stainless steel knife outside for a couple of days anywhere in the Pac Northwest in winter/spring and see what happens.........Even worse on the coast. "Salt Air". Surface rust is not a big deal. Spray on PB Blaster occasionally if you are really worried about it.
  3. Jan 29, 2016 at 9:09 PM
    That part of the shock is machined after zinc plating, so it is bare metal that will rust..same as a stock shock.
  4. Jan 29, 2016 at 9:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep just surface rust. You could treat it like Matt said and then spray it with something that will seal it up like rustoleum.
  5. Jan 30, 2016 at 5:33 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Fluid film is another product that works well for preventing rust.
  6. Feb 10, 2016 at 3:07 PM
    N8Dizzle
    Nate
    Seattle
    Thanks for the suggestions!
  7. Feb 10, 2016 at 9:10 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    What is rust?
