Toytec Boss kit VS Toytec Ultimate lift kit
Discussion in 'Suspension' started by Netmonkey, Nov 8, 2019.
  1. Nov 8, 2019 at 11:13 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    These two kits are similar in price and offer the same specs and features. so what is the difference between the two? does either have a any pluses over the other? are their rides comparable?
    + @Toytec Lifts
  2. Nov 8, 2019 at 11:36 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    It looks like the difference are the shocks. The Ultimate uses Billstein shocks, and the Boss kit is Toytec's brand of shock. I know of a few folks with the Boss kit and they love it. I don't know of any Ultimate users though.
  3. Nov 8, 2019 at 11:58 AM
    Netmonkey
    Georgetown, TX
    yeah, i had the ultimate kit on a previous truck and i was happy with it. i have also read favorable reviews about the boss kit too. i guess its 6 of one, half a dozen of another :)
  4. Nov 8, 2019 at 12:12 PM
    Squatting Pigeon
    Holden
    North Texas
    That would be my guess!
    I’m sure they’re both great kits :thumbsup:
  5. Nov 8, 2019 at 1:47 PM
    Maui BIGGUN
    Maui BIGGUN New Member
    Gabe
    2019 Toyota Tundra 4x4 Sport
    Probably posted before. But what is the biggest tire I can run on the stock tires. with the TOYTEC box 3" coil kit with rear shackels
  6. Nov 8, 2019 at 1:58 PM
    Netmonkey
    Georgetown, TX
    yeah... this is been covered in hundreds of threads. do a little searching... you will find the answer :)
  7. Nov 8, 2019 at 2:18 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    BOSS kit:
    • The BOSS branded products are Toytec's brand, so what we did was paired up with the engineering team at Eibach to build each shock and valve it specific for each vehicle we offer the product for.
    • The BOSS coilovers offer a threaded shock for ease of ride height adjustments from 1-3'' in the front end.
    • The BOSS coilovers offer a double zinc coated shock body along with a larger 5/8'' thick nitro steel hardened shock shaft for increased durability and corrosion resistance.
    • The BOSS rear shocks (in most cases) will offer more travel when comparing to the competitors shocks, most will be listed as an "extended travel rear shock".
    • BOSS Products offer a 1 year warranty, possibly able to push past the 1 year (case by case)
    Ultimate kit is just a standard Bilstein 5100 series front shock with a two piece custom aluminum machined sleeve and adjuster ring to make them a full ride height adjustable coilover system. A good benefit to these is that if and when a shock starts leaking, you are able to source a shock replacement local to you IF you are outside of the 1 year warranty or on a road trip/ wheeling trip.
    Let me know if you have any other questions!
    -David
    Netmonkey[OP] and Maui BIGGUN like this.
  8. Nov 8, 2019 at 4:59 PM
    David, are they both 700 lb springs, and 1 to 3 inches?
  9. Nov 11, 2019 at 9:40 AM
    Toytec Lifts
    Denver, CO.
    Yes and Yes :)
