Toytec Boss & Katzkin Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by PinoyRN, Jun 6, 2018.
  1. Jun 6, 2018 at 8:18 PM
    PinoyRN
    PinoyRN [OP] Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    Any advice on installing the Toytec Boss lift and leather Katzkins? I have both mods sitting in the garage that are waiting to be installed once I find the time. Thanks in advance!
  2. Jun 6, 2018 at 8:38 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    I just installed the Boss kit on my truck. It went ok but looking back I should have got the Toytec guys to do the install. Wrench turning was no issue, it's the knowledge of how each piece should fit or not fit that is priceless.
    4x4_Angel, TheBeast and Black Wolf like this.
  3. Jun 6, 2018 at 8:41 PM
    NCinCO
    Gary
    Thornton, CO
    But as long as you have a hammer, pry bar, and spray paint you'll be fine. :cheers:
    Tundradrenalin and Black Wolf like this.
  4. Jun 7, 2018 at 5:38 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I did the Katzkins on my Tacoma. My advice is to make sure you have the tools needed, hog rings, hog ring pliers, tie wraps (just in case), and a portable steamer is nice in case you need to steam out the foam compressions. You'll need an area to work on the seats because obviously you have to remove them. The headrests are a PIA to do, but they are doable, you just need to really compress the foam so the new leather fits over them - it will seem like they wont fit, but they will. It took me about 7-8 hours to do a doublecab Tacoma. That was removing the seats, removing the cloth and recovering the seats in leather and adding heat to the front seats. There are some good videos out there and there is some good info on Tacomaworld. All seats are pretty much the same when it comes to installing leather, the Tundra shouldn't be any different. I'm pretty confident after doing my Taco to where I could do it in the half the time if ever needed. But the Taco is gone and the Tundra has leather, so.... there's that..
    4x4_Angel likes this.
  5. Jun 7, 2018 at 6:04 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    As far as suspension, don’t hesitate to loosen cam bolts if needed to get the coil overs out. Just mark em and loosen em a bit, you’re gonna need an alignment anyway.
    4x4_Angel and Stroke250 like this.
  6. Jun 7, 2018 at 8:26 AM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Re: Boss kit. I installed it myself at it went pretty smooth. Assuming you don't have a vehicle lift, you'll need multiple floor jacks and two sets of jackstands, a 50-250 lb ft torque wrench, tie rod puller, etc. If you're not doing UCA's it will be very easy. The UCA's were the most difficult part and even they weren't bad. The whole thing took me 6 hours. The main thing is BUY THE RIGHT TOOLS if you don't have them. It's cheaper than paying someone to install and better than getting stuck half way through with your vehicle up in the air.
    Tie rod puller: Big inexpensive torque wrench: https://www.amazon.com/TEKTON-24340...=1528385113&sr=8-6&keywords=250+torque+wrench
    Thread HERE. Not an instructional thread by any means.
  7. Jun 7, 2018 at 8:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Neither of the projects are too technical. The advise above is good stuff. A good ball joint separator is key. Start exercising your hands now to prepare for the leather install....LOL I couldn't believe what a work out my hands got pulling and stretching the leather.
  8. Jun 7, 2018 at 9:38 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    For suspension tools, no need to buy tools just rent them. That is what I (AutoZone) did doing my brother truck and will be doing here soon again to change my front 3" lift spacers.
  9. Jun 7, 2018 at 9:44 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    All the advice shown here is good advice. IF you plan on tackling the task of installing our suspension yourself; here are a set of instructions to look over before tackling the task. We always recommend having a shop do it just for a peace of mind of it being done right, and for a "CYA" just in-case something happens during install.
    NewImprovedRon likes this.
  10. Jun 7, 2018 at 10:27 AM
    Hoologan
    Hoologan New Member
    California
    I use these opportunities as a damn good reason to buy tools. Over the years I've collected quite a collection.
    B737 likes this.
  11. Jun 7, 2018 at 2:12 PM
    PinoyRN
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    Awesome info, thanks guys.
  12. Jun 7, 2018 at 4:22 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Put the seat covers out in the sun for a while and heat them up so they stretch and are more pliable. I've done a ton of seat covers on older muscle cars and it always did the trick. Obviously you don't want them so hot they are tough to handle lol especially if you are working with black.
    JoshuaA likes this.
  13. Jun 21, 2018 at 7:58 AM
    PinoyRN
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    @831Tun
    Anybody know how to remove the cup holder plastic? I don’t want to break it!
    831Tun likes this.
  14. Jun 21, 2018 at 8:20 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I am considering a Katzkin install myself. If you happen to be snapping pics of your project and post them up with pointers, you’d be a hero!
  15. Jun 21, 2018 at 8:24 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sorry, I can't remember, it was my '07 and I did it in 2010, too long for ago for my memory. I think maybe it didn't come apart and the edges were stuffed under?
