Toytec Boss install help
Discussion in 'Suspension' started by Dabutcher, May 28, 2018.
  1. May 28, 2018 at 10:23 AM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I have replaced my front coil over shocks when I bought truck with oem new take offs. PITA but I was able to do it. Now I am installing new Toytech Boss coilover shocks. I got the shock in place and tightened up both ends after a lot of work and prayer. Now I cannot get top ball joint back in place on upper control arm? Truck is on stands and I am jacking under lower control arm . I can get it within six inches and get it the rest with a c clamp. But I cannot get nut on because clamp covers hole. With stock oem coilover shocks. I was able to do it this way .Oh yah .It is the hottest day of the year and I am in my driveway doing this. Any help would be great. Thanks. D
  2. May 28, 2018 at 10:38 AM
    DPlatinum
    DPlatinum New Member
    David
    DFW
    2017 Quicksand SR5 Doublecab 4x4
    Undercover Flex bed cover, Pro grille,2018 led headlights, bed step, console safe, Toytec/Eibach 3” front leveling shocks OEM painted to match fender flares, tow mirrors
    Wrap a ratchet strap around it in stead of a clamp. Tighten it down and you should be good.
    T-Rex266 likes this.
  3. May 28, 2018 at 12:00 PM
    Dabutcher
    D
    Twin Cities
    That worked to get it close and c clamp was able to get the rest. One done now after four hours straight in heat advisory smokin hot weather. Thank you so much. Peace. D
    4x4_Angel likes this.
  4. May 28, 2018 at 12:02 PM
    DPlatinum
    David
    DFW
    Great to hear you got it going your way
  5. May 28, 2018 at 4:48 PM
    Heatonrx
    Heatonrx New Member
    Had the same problem with the lower ball joint bolts. I swear it was hours on two bolts!
  6. May 28, 2018 at 5:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hmm don’t think I had this problem at all.
    I unhooked the lower control arm from the spindle and just used the jack under the lca to close the gap.
    4x4_Angel and equin like this.
  7. May 29, 2018 at 8:20 AM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Same here
  8. May 29, 2018 at 8:35 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I just paid sometime to do it:anonymous: but i don't have all the tools needed to do it yet
