Toyota Tundra pro vibrates
Discussion in 'Wheels & Tires' started by Ireland, Nov 17, 2017.
  1. Nov 17, 2017 at 2:48 PM
    Ireland
    Ireland [OP] New Member
    Kieran
    2016 Toyota Tundra pro
    Hey guys just bought a pro 2016, got wheels balanced and aligned. Still at 60+ vibrating, driving me crazy, dealer is taking it in on Monday and advise I can give the mechanic. Will this go away
  2. Nov 17, 2017 at 2:52 PM
    TheBeast The Beach
    road force balancing maybe ?
    joonbug and Law323 like this.
  3. Nov 17, 2017 at 3:05 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Is it a crew cab or double cab?
  4. Nov 17, 2017 at 3:05 PM
    Road force
  5. Nov 17, 2017 at 3:37 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Road force balancing and check the psi. If it's too low, until tires warm up, you will feel vibration going 60-70 mph.
  6. Nov 17, 2017 at 3:39 PM
    TheBeast The Beach
    also need pictures of the truck to evaluate said vibrations ;)
  7. Nov 17, 2017 at 3:40 PM
    Welcome from Texas! Let's see your ride
  8. Nov 17, 2017 at 4:53 PM
    Ireland
    Kieran
    Thanks guys will post a picture as soon as I figure out how to do it
  9. Nov 17, 2017 at 6:05 PM
    Ireland
    Kieran
    Also it's a crewmax
  10. Nov 17, 2017 at 6:12 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Interesting. I know it doesn't solve your problem, but when I purchased my Tundra last year, I test drove about 4 crewmax and 4 to 5 double cabs. Every crewman had steering wheel shake at highway speed - some worse than others, but none of the double cabs did. I ended up getting the DC.
    The suggestion of checking tire pressures and road force balancing is a good start. Good luck.
