Toyota tundra exhaust question
Discussion in 'General Tundra Discussion' started by ADN85, Apr 10, 2020.
  1. Apr 10, 2020 at 9:43 AM
    ADN85
    ADN85 [OP] New Member
    I own a 2016 Toyota tundra SR5 crewmax.
    I'm looking to upgrade my exhaust system.
    After a lot of research I found what I want but when chosing my truck option on the site, the only option for my year/make is a SR5 double cab 4 door.
    My question is: will it still fit even though it says for a double cab? I understand I don't want the option for double cab to be long bed. Just looking for opinions before I potentially spend money on product that won't fit or will need pipes extended/shortened. Thank you all.
  2. Apr 10, 2020 at 9:59 AM
    AZBoatHauler
    So.Arizona
    There is only one answer - contact Keith at @dirtydeeds and he will take care of all your exhaust needs and desires. [/Thread]
  3. Apr 10, 2020 at 10:03 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    TRUE! Keith is the man! I run the standard on my 2020 CM and it sounds kick ass! No drone with the resonator and plenty of growl when I stomp on the skinny pedal. Do yourself a favor don’t even bother with another system, @dirtydeeds is the way to go.
  4. Apr 10, 2020 at 10:13 AM
    ADN85
    Thanks for the input. I know exactly what I want and where to get it. I happened to find it much cheaper but not having crewmax option is throwing me off. All I need to know if 4 door double cab fits on a crewmax.
  5. Apr 10, 2020 at 10:25 AM
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    It will fit.
  6. Apr 10, 2020 at 10:28 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Fit should be fine. Drone, probably. If you replace the factory tailpipe after the y pipe you will lose low end torque
  7. Apr 10, 2020 at 10:33 AM
    Welcome from NY.
    Good luck with your decision.
