Toyota Tundra 2016 bracket bolt welded - can not remove to install trailer hitch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Arsenal1508, Sep 14, 2019.
  1. Sep 14, 2019 at 6:24 PM
    Arsenal1508
    Arsenal1508 [OP] New Member
    Hello,
    Does anyone know if this is normal for Toyota to weld the bracket that you need to remove for installing a trailer hitch? I was able to get the top bolts out, but the side bolts are welded. That's insane. Or am insane? Anyone, any recommendations to remove both these bolts will be highly appreciated. See picture below.
    Thank you
    Tundyfundy likes this.
  2. Sep 14, 2019 at 8:00 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I see the nuts are welded to the bracket but unless I’m missing something the bolt should still be able to spin and come out.
  3. Sep 14, 2019 at 8:19 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Loc-Tite would have been sufficient. Run the VIN and see if the truck came with a tow package. Looks like somebody bought the hitch, bolted it up, and welded/painted it. Very clean work but a bit too permanent and overkill for me.
    I could be wrong, but I've never heard of this being factory welded.
  4. Sep 14, 2019 at 8:22 PM
    AZTundra
    Paul
    Phoenix, AZ
    The nuts are welded to the bracket, but that doesn't stop you from removing the bolts and taking the bracket off.
    TheBeast and NewImprovedRon like this.
  5. Sep 14, 2019 at 8:28 PM
    Rubberdown
    Look on other side of bolt and use socket to remove bolt. Welds keep you from having to hold nut.
    I did this on an old tundra. It’s easier with the whole bumper off. The danged hitch replaces a big piece of structure so you might as well take it all apart.
    Pudge and too tall like this.
  6. Sep 16, 2019 at 1:28 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Looks like you tried to get off those welded nuts for a while! :frusty: The other side of the frame is where you'll find the bolts that turn.
  7. Sep 16, 2019 at 1:32 PM
  8. Sep 16, 2019 at 1:34 PM
    Tundyfundy
    Bay Area, CA
    I was wondering who was going to address the elephant in the room. LMAO
    PS: those bolts look wonky. Weird angles like one is bent. Maybe just the camera angle.
  9. Sep 16, 2019 at 1:36 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Yup nuts are welded to frame
    Black Wolf and Tundyfundy like this.
  10. Sep 16, 2019 at 1:37 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Bolts are self tapping I do believe
    Migraine and Tundyfundy[QUOTED] like this.
  11. Sep 16, 2019 at 5:17 PM
    Arsenal1508
    Got them off
    Like everyone said, got it from the other side.
    Thank you
    Migraine, Pinay, Tundyfundy and 3 others like this.
  12. Sep 16, 2019 at 5:27 PM
    Kuul!. Why are you removing the hitch anyways now that the bolts are off?
  13. Sep 16, 2019 at 6:03 PM
    Nevermind... forgot you are putting a new hitch on.
  14. Sep 16, 2019 at 10:44 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    Bolts are tapered to make installing them easier, kind of like self aligning.
    NewImprovedRon likes this.
