Toyota Tundra 2014 stuck sun roof
Discussion in 'New Member Introductions' started by mintowt, Mar 10, 2025.
  1. Mar 10, 2025 at 11:39 AM
    mintowt
    mintowt [OP] New Member
    I am new here and believe I will be back many times – I helped my son buy a Toyota Tundra – 2014 Platinum with only 100,000 miles on the clock! What a beast! Amazing truck. We were aware of one issue whereby the sunroof was stuck in the tilt position and non functional which was actually what brought me to this wonderful forum. What a wealth of knowledge. Anyway BIG thanks to Gasman675 for his excellent posting which was a real help. I should add that this video was fantastic:
    https://www.google.com/search?q=how...ate=ive&vld=cid:cf165643,vid:sNcTpNJyk_s,st:0
    Needless to say the problem has gone away and everything is fully functional. I should add that we followed the instructions, removed the motor, and disassembled the required components – not difficult. Cleaned them all up (Ohh I love my Drimel) Then reassembled it all and the entire mechanism worked flawlessly. Total cost ZERO total time 30-45 minutes. I should also add that there is an omission in the “posted fix” which is not to say "remove the screws" leading someone to think they are flat head or Phillips. They are NOT they are Torx screws so be aware or you will fall at the first fence. Anyway sincere thanks to the forum – great site.
  2. Mar 10, 2025 at 5:55 PM
    Welcome from NY.
  3. Mar 10, 2025 at 8:27 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. Mar 15, 2025 at 2:54 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Welcome from NC :hattip:
