Toyota tundra 2013 uo155
Discussion in '2nd Gen Tundras (2007-2013)' started by Muhanad, Apr 20, 2022.
  1. Apr 20, 2022 at 11:39 AM
    Muhanad
    Muhanad [OP] New Member
    i get toyota tundra 2013 TRD warrior and i would like to change the cluster to the optitron one but i had some issues with this I try 2 different part no which i have the code uo155 Code U0155 indicates the instrument cluster with check engine light and 4Lo blinking
    the part of the cluster : 83800-0C570
    83800-0CF10-A
    MY VIN : 5TFDW5F16DX302421
    this cluster (83800-0CF10-A) i bought form tundra 2010 platinum vin : 5TFHW5F17AX152574
    WHEN I CHECK THE connector OF THE CLUSTER I SEE THERE'S DIFFERENT BETWEEN MY car and the 2010 ON PIN 21,22
    5163ced7-71e8-486d-ac4f-e468ac576800.jpg 3e8485cc-6597-460a-b3a5-9c45b9032faa.jpg 2571aa32-510c-440a-b3a8-c091b20a19c6.jpg 24206884-f439-400f-8ce9-a918e61b9b88.jpg
  2. Apr 20, 2022 at 11:59 AM
    @e30cabrio Any ideas?
  3. Apr 20, 2022 at 12:07 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I had no issues with an Optiron in my 2010, That code means the cluster is not getting the data it expects from the computer. What vehicle were the clusters you used from?
    This is what happened when I put the 2019 Sequoia cluster in my 2013 Sequoia.
    Code U0155 indicates the instrument cluster is not receiving or transmitting messages on the CAN bus.
    @Jeff_5_7 might be able to asisst?
    baraynavab likes this.
  4. Apr 20, 2022 at 12:30 PM
    e30cabrio
  5. Apr 20, 2022 at 12:41 PM
    Eze915
    Eze915 New Member
    Edgar
    2013 Black Tundra CM 4x4
    so i changed my 2013 to the optitron cluster but the MPG, distance to empty info doesn't display anything. i believe the cluster i put in came off of a 2008. would i be able to get the display to work by changing out some of the wiring? sorry for pigging backing on this thread. any help would be appreciated
    Jeff_5_7 likes this.
  6. Apr 20, 2022 at 5:46 PM
    Muhanad
    event i don't know which cluster part no will fit my vehicle this is my vin : 5TFDW5F16DX302421 ?
  7. Apr 20, 2022 at 7:59 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The white and yellow wires, Pin 21,22, are the CAN High and Low pins to connect the cluster to the communication network. Toyota calls the cluster the combination meter.
    Seems your truck doesn’t have them. If you look at the diagram they are *1, which means on trucks with seat position memory had this wiring. Notice the note in the top of the photo.
    If you wanted you could probably tie into the other CAN H and CAN L and that would fix your problem. Run a wire out of Pin 21 and tie it to Pin 34, same for Pin 22 jump it into Pin 33. Basically run the other CAN connection to the cluster to location 21,22 also
    Also I ran your VIN, is your truck flex fuel? If so your fuel gauge might be off with the new cluster.
    @e30cabrio I assume yours has seat memory from the factory so all wiring was present when you did the swap.
    Tundra3k likes this.
  8. Apr 20, 2022 at 8:05 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yes you can get it to work. Did yours truck have the info buttons and shoe MPG on the accessory meter by the clock from the factory?
  9. Apr 21, 2022 at 8:41 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Hey how do you look up DTC's on the Kenwood radio? thats cool..
  10. Apr 21, 2022 at 9:51 AM
    Eze915
    Eze915 New Member
    Edgar
    yes it does have the buttons and it showed the MPG on the clock screen. *note it didn't have the info button when i bought it last year. i found some at my local junkyard and installed them and it displayed MPG info perfectly .
  11. Apr 22, 2022 at 9:26 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    if your info button was working before its odd it’s not working now. Did you have to add the 2 wires to get the info button to work or did you already have all the necessary wires?
    when I installed my optitron cluster my button stopped working bc I had to add the 2 wires and when removing the dash I guess I pulled the wires out some. Reseated the wires and all works fine now
  12. Apr 22, 2022 at 12:03 PM
    Eze915
    Eze915 New Member
    Edgar
    It was plug and play. it worked fine without having to do anything.
  13. Apr 26, 2022 at 9:22 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Do you know which 2 wires you added? I assume to get the buttons functioning?
  14. Apr 26, 2022 at 9:27 AM
    Musicmasterd12
    Southern Louisiana
  15. Apr 27, 2022 at 4:40 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    @Musicmasterd12 @e30cabrio did your trucks have the CANL and CANH lines in positions 21 white, 22 yellow. I have seen pictures of Eze915s wiring and he like the original poster is only missing the CANL CANH in pin 21,22. I wonder if the fuel consumption data for the optitron comes in on these lines. I know its a CAN signal.
  16. Apr 29, 2022 at 6:02 AM
    Musicmasterd12
    Southern Louisiana
    where are those pins located? On the back of info button?
  17. Apr 29, 2022 at 6:39 AM
    e30cabrio
    I have an IDATALINK Maestro RR2 that enables the steeringwheel switches, Escort radar detector & gauges/car functions like clearing CELs
    I don't know, I will take a picture next time I take my dash apart.
  18. Apr 29, 2022 at 9:30 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    on the cluster wiring, the connector that plugs into the cluster. Wondering if yours has pin 21,22 wiring
  19. Apr 29, 2022 at 10:15 AM
    Musicmasterd12
    Southern Louisiana
    I think pin 22 is what we talked about running a wire from when I was trying to get the optitron cluster gauge to dim and if so I do not have a wire there. I don’t remember about pin 21 but don’t believe it had a wire there.
  20. Apr 29, 2022 at 10:18 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    It should be these the black and yellow, you will either have both or none
  21. Apr 29, 2022 at 1:06 PM
    Musicmasterd12
    Southern Louisiana
    Ah ok. I don’t remember. And unfortunately I won’t be pulling it back apart anytime soon. Sorry
  22. May 8, 2022 at 7:24 AM
    e30cabrio
    Here are the wires from my 2013 Sequoia Limited:
