Toyota tundra 2007 5.7 litter
Discussion in '2nd Gen Tundras (2007-2013)' started by Acuario, Oct 29, 2022.
  1. Oct 29, 2022 at 11:25 AM
    Acuario
    Acuario [OP] New Member
    Lucio
    toyota tundra 2007
    Does anyone know how much Volts does a Variable Timing Solenoid use? I checked on my tundra 2007 and is showing only 2.37 volts on all 4, on my voltmeter. Is this correct?
  2. Nov 2, 2022 at 9:40 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Good question.. No idea. How did you check it? Maybe others can try that and get back to you with a reading?
  3. Nov 2, 2022 at 9:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The “voltage” will vary, as it is a PWM (pulse width modulation) output from the ECU. Basically the ECU can vary the voltage to to solenoids with more or less rapid pulses to control cam timing based on feedback from the cam position sensors for the current RPM, load, etc. They are not a on / off, all or nothing sorta thingamobob.
    Any reason you’re measuring? Fault codes, or issues?
