Toyota spray on bed liner question
Discussion in '2.5 Gen Tundras (2014-2021)' started by fisherman951, Oct 26, 2017.
  1. Oct 26, 2017 at 7:53 AM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    So i noticed something weird about my spray on bed liner. The 2 rear tie downs loops arnt sprayed for some reason. Does any one have this also or should i take it back to toyota and have them spray it? The front ones are sprayed. 20171026_072405.jpg
  2. Oct 26, 2017 at 8:07 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’d rather have mine unsprayed than sprayed over incase you ever need to remove it. Most Linex dealers don’t spray them neither.
    831Tun, 15whtrd and zcarpenter92 like this.
  3. Oct 26, 2017 at 8:48 AM
    Theonlyway
    Theonlyway New Member
    User
    My line-x dealer sprayed mine ;)
  4. Oct 26, 2017 at 8:50 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    I just find it weird that the front 2 are sprayed. And the rear arent. And now that i noticed it its bothering me lol
    joonbug and TheBeast like this.
  5. Oct 26, 2017 at 8:52 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    It just depends on who does it. I've noticed on here that some have them done and some don't. The same goes for the bolts that hold the bed on, some people's are sprayed, some people's aren't.
  6. Oct 26, 2017 at 8:53 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    That is weird but I would prefer none of them to be sprayed. No point to it.
  7. Oct 26, 2017 at 9:06 AM
    TheBeast The Beach
    mine are sprayed but the bed bolts are not. I'd rather have the tie downs sprayed to protect from rust/use.
    Theonlyway likes this.
  8. Oct 26, 2017 at 9:22 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    mine are sprayed over, but my bed bolts aren't. I still spray the bolts every once in a while to prevent rust.
    NewImprovedRon likes this.
  9. Oct 26, 2017 at 9:42 AM
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    I have the "factory" spray on. Fronts are sprayed rears are not. I'm not OCD about this however. And I would not take it back to the dealer to have them sprayed because they are likely to F it up and may cause more problems than its worth. If the color difference bothers you I'd just use adhesion promoter followed by a spritzing from a quality black semi-gloss. Problem is that any coating on hooks is likely to wear off anyway. I wish they were stainless steel.
    geno0506, 831Tun and Watt maker like this.
  10. Oct 26, 2017 at 9:46 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Mine are sprayed
  11. Oct 26, 2017 at 10:15 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    mine too but not factory. none of the bolts are including bed bolts
  12. Oct 26, 2017 at 10:58 AM
    rzanini
    rzanini New Member
    Ryan
    2017 Silver Tundra Double Cab
    mine are all sprayed but the bed bolts are not.
  13. Oct 26, 2017 at 11:45 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Mine looks exactly like yours and the paint has all chipped off of them from being used.
  14. Oct 29, 2017 at 8:00 PM
    TTund16
    TTund16 New Member
    I was also curious since my 2016 w/ factory spray is like that. maybe its the way manufacturing process flow is and they spray before the back pieces are installed. I wouldn't worry about rust. my 20 years old Tacoma tie downs are still not rusted and they were just painted black.
  15. Oct 29, 2017 at 9:12 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    My "factory" sprayed bed liner was sprayed over the tie downs.
  16. Oct 29, 2017 at 10:44 PM
    TTund16
    TTund16 New Member
    maybe there is no process/flow since everyone's is different ... lol
    it got my attention since it was not consistent. I have front sprayed but not the back like OP!
  17. Oct 30, 2017 at 6:59 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I think it depends on whether the spray on bed liner is installed at a local dealer (such as Linex) or whether it is a distribution center (which I think is where mine was done) or "factory" if there is such a process.
  18. Oct 30, 2017 at 8:15 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Typically dealers will use a local Line-X shop, at least that's what I have seen working with a local Trailer dealer who also has a Line-X shop he has all the local dealers coming to him for Line-X. They farm it out and factor it into the cost of the truck. Mine is sprayed with everything covered, bed bolts, tie downs, etc. I wish they had done over the rail and covered the plastic bed rails as well. I'm probably going to remove them and have them encapsulated with Line-X like I did with my boat cap. Something about Line-X people don't realize, they can do just about any color now with the top coat. Light colors like white will yellow from the undercoating bleed through but every other color holds up well with no issue. I had my boat cap done in a sea green/blue 3 years ago and it sits outside and still looks like brand new.
  19. Oct 30, 2017 at 8:44 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I have the factory spray option on my truck and the rear loops aren't sprayed. Maybe by design? It was nice they weren't sprayed when I installed the factory bed extender brackets in the back, since they require the tie down points to be removed/reinstalled.
  20. Oct 30, 2017 at 10:57 AM
    nodak67
    nodak67 New Member
    JR
    the line-x color option is about $125 more I think
  21. Oct 30, 2017 at 11:02 AM
    birdman076
    Chuck
    Montana
    It varies from dealer to dealer but there is an up-charge because they use the "Premium" top coating to do the color with.
  22. Oct 30, 2017 at 5:26 PM
    Tundra2424
    Tundra2424 New Member
    Andy
    2016 Tundra Platinum
    3” lift, Sota Novakane 20” wheels, Nitto Terra Grapple G2 35x12.50 r20, Borla dual exhaust
    Mine are also sprayed.
  23. Oct 30, 2017 at 6:41 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m willing to bet it’s nothing but human laziness. The rear ties are easy to remove or mask but the front ones require crawling up there on your knees cause they are hard to reach over the bed side.
    Some people are less lazy, so that is why there’s no consistency
  24. Oct 30, 2017 at 10:04 PM
    Stuffs
    Stuffs New Member
    My 18 are just as you described. Front two are sprayed, rear two are not. I think it has something to do with using the rear two to mount the bed extender brackets so leaving them bare would make it easier..not 100% but the dealer mentioned something like that.
    Its not really a big deal. If anything, I wish they left all 4 untreated.
  25. Oct 31, 2017 at 2:39 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    None of mine are sprayed and neither are the bed bolts. When I took delivery of the truck it was not sprayed. The dealership had the local Line-X company do it.
  26. Oct 31, 2017 at 3:18 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    My linex dealer asked what I wanted. I had tie downs sprayed, bolts not sprayed
  27. Oct 31, 2017 at 8:37 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    the tie downs and bolts are sprayed in mine, factory spray liner
  28. Nov 1, 2017 at 10:47 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    I suggest that you let them know what your preferences is. That being said I did it with my friend and had him do the whole area and also the tailgate extender.... better safe than sorry
  29. Nov 2, 2017 at 5:46 PM
    ncmtnman
    ncmtnman New Member
    Robert
    2016 Tundra Limited....and then some
    Level kit, Pro mods, shell, lights, and then some
    I’ve got a 2016 with the Toyota spray in and they sprayed everything in mine. I get a little obsessed with my truck and having everything finished the same, so I’d take it back to the dealer and make them respect it
    geno0506 likes this.
  30. Nov 24, 2017 at 10:27 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    In my 2017 the front two are sprayed and the back two are not...weird. I ordered the factory bed rails after I purchased the truck, they should be here Tuesday. How many holes should be present to bolt the bed rails to? It seems like they maybe sprayed over some, but I don't know....
