Toyota Service Bulletin 0166-19 (Extended Crank)
Discussion in '2.5 Gen Tundras (2014-2021)' started by nhw544, Jul 26, 2024.
  1. Jul 26, 2024 at 3:05 PM
    nhw544
    nhw544 [OP] Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Hey all, long time no post. Life’s been hectic but I hope all of you are doing well!
    Wanted to get some opinions. Last Saturday, for the first time in 20 years of owning Toyotas, I had a no start situation that wasn’t battery related. Went out to start the truck and it just kept cranking but would not fully start. Tried jumping it just to see what would happen and same thing, long crank but no start. Also no check engine lights. So we took my wife’s Highlander out and when we came back after about 4 hours I went to start the truck and it fired right up with no issues since then.
    Sunday I tested the battery and the battery was good. So I took it to my buddy’s shop on Monday and they couldn’t replicate the issue. I had sent my buddy a video of the truck not cranking so he at least was able to see it even though they couldn’t replicate it. He told me they pulled a few codes which lead them to TSB 0166-19, which states this is an ecu update issue and/or a fuel pump issue.
    So today I take the truck to my local dealer and gave them the info my mechanic told me. They agreed that it looks like it would fall under this TSB and recommend doing the ecu update and fuel pump.
    Does anyone have any experience with this issue or the TSB fix? I’m tempted to just try the ecu update and see how that goes because the fuel pump is going to cost almost $1700. Any insight would be appreciated!
  2. Jul 26, 2024 at 3:21 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
  3. Jul 26, 2024 at 3:25 PM
    nhw544
    RVA
  4. Jul 26, 2024 at 3:28 PM
    FireFinder44
    Albany, OR
    I would ask, and buck it higher. I had to pester Chrysler 20 years ago to replace the rotors in my Grand Cherokee, because they had to be turned like every 15k miles because they were kind of small for how heavy the vehicle was. Eventually a TSB came down, but I was well out of warranty, and got them to give me the parts, and I paid labor.
  5. Jul 26, 2024 at 3:40 PM
    nhw544
    RVA
    I certainly will try!
    We leave for vacation tomorrow, so I didn’t commit to anything yet. Praying I don’t have any issues while we are at the beach.
    FireFinder44[QUOTED] likes this.
  6. Jul 28, 2024 at 6:46 AM
    nhw544
    RVA
    Ok so it happened again this morning. Both times this has happened has been the day after getting fuel. Coincidence?
  7. Jul 28, 2024 at 7:13 AM
    Observer
    Observer New Member
    Curious, I assume your filling up both vehicles at the same gas station.
  8. Jul 28, 2024 at 7:21 AM
    nhw544
    RVA
    Nope, different gas stations. Just didn’t know if there was something about filling up that would trigger the fuel pump to go wonky.
    We are actually at the beach for the week. Closest Toyota dealer to me is Wilmington Toyota or Sparks. So I’m gonna have to call them and see if they can help me out while I’m down here and get this taken care of.
  9. Jul 28, 2024 at 8:02 AM
    Observer
    Observer New Member
    Hopefully they can figure it out. Wish you the best of luck.
    nhw544[OP] likes this.
  10. Jul 28, 2024 at 8:09 AM
    FireFinder44
    Albany, OR
    FFV? Any chance you can put ethanol free gas in the tank? I like to do that once or so a year, I typically get ethanol free gas for the pressure washer/lawn mower.
  11. Jul 28, 2024 at 9:39 AM
    nhw544
    RVA
    It is a flex fuel. It’s possible that I did but I don’t think so. We don’t have many ethanol free pumps near me. But I’ll look at where we got fuel yesterday and see if that’s an option. Thanks for the suggestion because I didn’t think of that!
  12. Jul 28, 2024 at 9:40 AM
    nhw544
    RVA
    Appreciate it!
  13. Jul 28, 2024 at 10:01 AM
    AZBoatHauler
    So.Arizona
    @ToyoMafia sound familiar?
    resetting the ethanol setting should fix it - although likely temporary.
    ToyoMafia and nhw544[OP] like this.
  14. Jul 28, 2024 at 11:58 AM
    nhw544
    RVA
    The dealer didn’t mention that, but I will see if they think that’s an option.
  15. Jul 28, 2024 at 12:00 PM
    AZBoatHauler
    So.Arizona
    KNABORES, ToyoMafia and BillyB like this.
  16. Jul 28, 2024 at 12:56 PM
    nhw544
    RVA
    ToyoMafia likes this.
  17. Jul 28, 2024 at 1:35 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    The dealer won’t tell you the truth. They will say something about a fuel pump service bulletin at best. Your fuel pump is fine.
    nhw544[QUOTED][OP] likes this.
  18. Jul 28, 2024 at 1:36 PM
    ToyoMafia
    Magic carpet.
    It’s real hot down here. 18 hours off then start is still a cold start.
  19. Jul 28, 2024 at 2:08 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Is the ffv pump different than a non ffv pump? $1700 to replace a $2-300 pump is ridiculous. When I installed my supercharger, I had to replace the pump. Taking my sweet ass time it too me 2 hours at most. What's the dealer charging for labor?
  20. Jul 28, 2024 at 4:54 PM
    ToyoMafia
    Magic carpet.
    What’s worse is the pump doesn’t fix the problem.
    KNABORES and pursuit2550[QUOTED] like this.
  21. Jul 28, 2024 at 5:53 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Do you have a 2nd key/FOB in the closet key box? If you do grab it next time you have the issue and try it (getting your "original" key far away.)
    Know that if the battery in your key/FOB starts going out/dead it won't complete the "handshake" with the immobilizer circuit (theft deterrent system) and therefore the truck will think its being stolen and won't let the fuel pump send fuel.
    Tripleconpanna likes this.
  22. Jul 28, 2024 at 7:13 PM
    nhw544
    RVA
    So did you go through this problem as well? I’d hate to spend that much money and not have it fixed.
    ToyoMafia[QUOTED] likes this.
  23. Jul 28, 2024 at 7:14 PM
    nhw544
    RVA
    I have a 2nd fob, but it’s back at home. But I will try it once we get back if it happens again. Thank you for that suggestion, didn’t even think about that.
  24. Jul 28, 2024 at 7:16 PM
    nhw544
    RVA
    I do have aftermarket remote start. If this happens again, if I can get it started with the remote start app would that lead towards the key fob or would it kill it once I put the fob in?
  25. Jul 29, 2024 at 4:23 AM
    ToyoMafia
    Magic carpet.
    Yes. Mine was a warranty repair. They had my truck for 11months. The replaced the pump and reset the ECU. Problem was back within 4-6 months. I bought a computer and now just reset the % when necessary
  26. Jul 29, 2024 at 6:05 AM
    nhw544
    RVA
    Ok still not starting as of this morning. Closest dealers to me right now are Hendrick in Wilmington or Sparks in Myrtle Beach. Anyone have a recommendation?
  27. Jul 29, 2024 at 6:33 AM
    nhw544
    RVA
    The reason I own Toyotas for my daily drivers is to not have to worry about crap like this and being stranded on vacation. Man this is frustrating.
  28. Jul 29, 2024 at 8:21 AM
    AZBoatHauler
    So.Arizona
    No other electrical mods besides the remote start? No add-a-fuses plugged in anywhere?
  29. Jul 29, 2024 at 8:26 AM
    nhw544
    RVA
    None. Besides the 12v Solutions remote start, the only other mods I’ve done are tires and wheels. I had put an aftermarket HU in last fall but I hated it and put it back to the stock HU.
  30. Jul 29, 2024 at 8:32 AM
    AZBoatHauler
    So.Arizona
    You might be able to get your hands on an OBD computer or Carista module to reset the ethanol percentage quicker than you can get an appointment with the service center if you want to try to handle it yourself.
