Toyota Ruined my Battery
Discussion in 'General Tundra Discussion' started by Solv3nt, Jun 14, 2024.
  1. Jun 14, 2024 at 11:55 AM
    Solv3nt
    Solv3nt [OP] New Member
    Oregon
    2021 SR5 Off-Road 4x4
    Driver side grab handle, Genuine Cooling System Transmission cooler package, Max Modular Bed Rack, White Knuckle Off-road sliders, undercover ultra flex tonneau cover
    Not that it really matters, other then me feeling better about venting. My '21 battery cables were getting really corroded. Apparently, Toyota had tightened the straps down enough to damage the battery. Now they are refusing to do a warranty replacement.
  2. Jun 14, 2024 at 11:57 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sounds like the dealer ruined your battery, not Toyota.
  3. Jun 14, 2024 at 11:59 AM
    Solv3nt
    Oregon
    Dealer shouldn't have ever had the battery out. My truck was port recalled before I ever got it for the steering column.
  4. Jun 14, 2024 at 12:17 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If it makes you feel any better, the factory battery lasted about as long as they do. 2021 would be needing a new battery about now regardless. OE batteries typically take a dump about year 3.
  5. Jun 14, 2024 at 12:19 PM
    Solv3nt
    Oregon
    I'm more upset about Toyota not standing by with the warranty. I don't care about the cost so much. The battery is holding pretty well though. I'm one of those irritating consumers that will leave based off of poor customer service.
  6. Jun 14, 2024 at 2:34 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    How did they ruin the battery? If they broke the post, or cracked the case, a few pictures to regional or corporate should get a response. You should probably replace the terminals if they were damaged, and maybe the cables if the corrosion was excessive. I have a couple of independent mechanics that I go to for any work. Both know to not touch my battery terminals.
    Liberal use of these will help avoid future problems.
    ATV25, 1lowlife and Solv3nt[OP] like this.
  7. Jun 14, 2024 at 4:07 PM
    Solv3nt
    Oregon
    They tightened the battery holder too much and the battery is leaking. The cable ends are really corroded and need replacing. I'm at the Ford dealer looking at an F250.
  8. Jun 14, 2024 at 4:11 PM
    AZBoatHauler
    So.Arizona
    Sounds like a good reason to get rid of the truck.
  9. Jun 14, 2024 at 4:37 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    Yep
    I will make an offer OP
    Black Wolf and texasrho83 like this.
  10. Jun 14, 2024 at 4:39 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Heads up: Toyota ruined the truck.
  11. Jun 14, 2024 at 4:43 PM
    Yep...corroded battery terminals. Hard pass.
  12. Jun 14, 2024 at 4:43 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tragic loss
  13. Jun 14, 2024 at 4:46 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  14. Jun 14, 2024 at 4:47 PM
    AZBoatHauler
    So.Arizona
    Sounds like a cracked battery housing - the terminals are fine.
    I heard everything came out assembled perfectly during the Covid lockdown.
  15. Jun 14, 2024 at 4:59 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    How many batteries do you typically go through on your impact when tightening the battery hold down? I usually stop at 1 and a half.
  16. Jun 14, 2024 at 5:07 PM
    RobertD
    Robert
    DFW, Texas
    What size batteries? Just making sure we are using the same or similar size comparatively.
    I normally have an 18volt 4amp battery on my impact.
    BillyB and TRDFerguson[QUOTED] like this.
  17. Jun 14, 2024 at 5:13 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What in the hell is the purpose of this thread? :poking:
  18. Jun 14, 2024 at 5:13 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    So sorry.
    Now show me on the battery where Toyota touched your terminals.
  19. Jun 14, 2024 at 5:13 PM
    AZBoatHauler
    So.Arizona
    Did you not read the OP? It’s for him to feel better.
  20. Jun 14, 2024 at 5:15 PM
    To inform us that he's looking at a Ford today. I guess
    Tripleconpanna and 1lowlife like this.
  21. Jun 14, 2024 at 5:18 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Just get a new battery is probably the move
    My '21 battery is doing good still, I heard you can get a better than OEM battery so when that time comes I will "upgrade". What battery should I select when that time comes??
    BillyB and Black Wolf like this.
  22. Jun 14, 2024 at 5:25 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Waaaa I didn’t get my way. I’ll show them. Pretty much summed up society. Good luck…with everything!
  23. Jun 14, 2024 at 5:28 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Amazon Basics.
  24. Jun 14, 2024 at 5:31 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Ya Dude
    Lotta Parts
    Very Nice
    FrenchToasty likes this.
  25. Jun 14, 2024 at 5:39 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So probably roughly what 1.5 of my 6Ah Ryobi batteries do
    RobertD[QUOTED] likes this.
  26. Jun 14, 2024 at 5:49 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    My OEM battery lasted 6 years. I only replaced it becase I was going on a trip. Yes it got a lot of the white corrosion products, but a can of Coke cleared it right up. My daughter's Yaris looked like it had been snowed on, Again a can of Coke and a wire brush fixed it.
  27. Jun 14, 2024 at 6:05 PM
    Solv3nt
    Oregon
    It's the frustration that Toyota isn't backing their product, and are willing to lose a customer over a $400 repair.
    The Ford dealer rejected my offer. Ha!
    Black Wolf likes this.
  28. Jun 14, 2024 at 6:10 PM
    yakeng
    I had the OEM battery in my F-150 last 5 years. Tundra lasted just about over 3. I think it’s a crapshoot when it comes to batteries.
    JMB[QUOTED] likes this.
  29. Jun 14, 2024 at 6:17 PM
    JMB
    Chesapeake, VA
    Agree. No matter where they come from. The cat makers don't make batteries. They just buy them.
  30. Jun 14, 2024 at 6:24 PM
    Solv3nt
    Oregon
    The battery isn't the problem, other then it being damaged by Toyota.
