Toyota oil requirements...
Discussion in 'General Tundra Discussion' started by Eric32444, May 14, 2019.
  1. May 14, 2019 at 11:27 AM
    Eric32444
    Eric32444 [OP] "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    so the manual says 0w20 viscosity is "recommended"....this is not a requirement.
    it says if a 5w20 is used, you "must" go back to 0w20 next oil change. This to me means the "0" portion of 0w20 is the most important that "could" be interpreted as a requirement.
    i don't think they could give you a warranty issue on a 0w30 or 0w40 oil. Hell, as long as its Ilsac-5, i dont think they could deny any warranty claim from the oil. They don't prohibit any oil in the manual at all.
    anyone see anything different?
  2. May 14, 2019 at 11:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just by the logic you used to determine that the 0 was the most important.
    You could also arrive on 20 being the most important. As it is the only number common to both oils mentioned.
    That said, I have run 5w-30 in the 5.7 with zero problems
  3. May 14, 2019 at 11:58 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I’ve been using 5w-30 also.
    Eric32444[OP] likes this.
  4. May 14, 2019 at 1:38 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    5w30 used to be the spec for the 5.7 I think, 0w20 is only there to satisfy CAFE and govt bs I believe. I think our motors should be on something like 5w30, mine in the hot months with 0w20 makes a heck of a racket.
    BecauseRacecar likes this.
  5. May 14, 2019 at 2:13 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would imagine where you live is important too. In southwest it is almost 80-90 degrees (hotter in some spots) for half the year. I probably wouldn’t run 5w oil if I lived in a colder area
    I will say, 30w oil shuts up the valve chatter at idle....
    Trooper2 likes this.
  6. May 14, 2019 at 2:19 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I bought 5w-20 for first oil change. Never looked at cap just had 5w on my mind. I think I will stick with it here in TX. I had a PoS 5.4 Ford Triton that drank 0W-20. I had to switch to a heavier oil on it to keep consumption in check. Quart per 1500 miles well within Ford's spec. Ford replaced some 5.4s early on but got tough. Just glad I checked it and caught the consumption.
  7. May 14, 2019 at 4:13 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Toyota engineers know what they are doing. I trust them over a forum users "feelings" about what the engine should run or the average joe thinking they know what is best for the engine. Toyota engineers know what is best for the engine and they say 0w20.
    0w20 performs wonderfully and has been proven with science and through thousands and thousands of used oil analysis tests.
  8. May 14, 2019 at 4:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    How’s the coolaid taste today?
    Just kidding! :boink: I drink the recommended 0W20 as well. And fill my engine with beer. Or maybe that’s backwards. :notsure:
    Kgfit85, ATV25, Undercover and 6 others like this.
  9. May 14, 2019 at 4:50 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    No doubt the engineers know what there doing, but then there is people above them telling them they need to hit certain Cafe and mpg standards. Old spec was 5w30, same motor now 0w20.
  10. May 14, 2019 at 4:56 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    0W20 all year long no issues.
    Blueknights75 likes this.
  11. May 14, 2019 at 6:00 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    In a northern clime I would not use anything else. For cold weather starts you definitely want a thinner oil. I remember the days of single weight oils and switching to lighter weights in winter. I think in southern climes 5w is fine. Maintenance manuals cover all climes and no longer specify different oils for colder ones.
  12. May 14, 2019 at 6:41 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    0W or 5W. It's of ZERO consequence if you take a few minutes and warm the damn oil and engine up. That 0W might be a bit nicer if you're prone to: start it up, jam it in drive, and sail away at 2,500/3,500 rpms.
    Me? I always let the oil/engine warm up a bit before I take off when it's cold.
    And now the part my lawyer asked me to include: YMMV.
  13. May 14, 2019 at 6:51 PM
    Blueknights75
    Ron
    Clayton, NC
    X2
    Y0TA PR0[QUOTED] likes this.
  14. May 14, 2019 at 7:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I don’t doubt this at all. But I also think many things can be true at once. 0-20 could be great. As could 5-20, 0-30 and 5-30.
    I have tried 0w-40 and the engine didn’t feel the same. Maybe it was in my head. Drained it and replaced with 5-30, ran much smoother
  15. May 14, 2019 at 9:29 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Why do people have to use something different than what is on the cap. Use the oil determined by the manufacturer. It's synthetic 0w-20 and that's it. Toyota can't be more clear than that in the manual and on the cap. They know more than some of you guys "feel" or "think" is best. How many of you have the equipment and education for true oil analysis?
  16. May 14, 2019 at 10:28 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I want to keep my cam towers gaskets soaked in chit as thick as molasses... LOL
    landphil likes this.
  17. May 14, 2019 at 10:53 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  18. May 15, 2019 at 4:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I run 5-30 in mine as well. I've read that in other parts of the world the Tundra specs for 5-30. Only in the US is the 0-20 specified.
  19. May 15, 2019 at 4:08 AM
    Got a link to what you read?
  20. May 15, 2019 at 4:34 AM
    Ronin73
    Ronin73 New Member
    The engine overall is the same, but I bet the tolerances of the engine have gotten tighter---and that is where the 0w20 would be the better oil spec to run.
    astro-jason likes this.
  21. May 15, 2019 at 4:42 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Without proof of that I bet that's not the case, no way Toyota changes specs on the engine mid cycle for an oil. Shoot they cant even fix the cam tower leak which would cost the $. Until its a revised motor like Nissan did with the new Titan reworking the 5.6 then I bet specs are the same.
    I run the 0w20 in mine like the cap says I just feel the motor is pretty noisy with it in the summer months.
    Terndrerrr likes this.
  22. May 15, 2019 at 5:08 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    0W-20 all year long for me. If it needs some warming up in the winter, I have a block heater on it. I think that I read that some newer small engines are now specing 0W-16, imagine that!
  23. May 15, 2019 at 6:32 AM
    Ronin73
    Ronin73 New Member
    Then you'd be wrong. If you don't think Toyota makes small changes to the engine throughout its cycle that are not really publicized, then you are very naive. Mike Sweers admits that in this clip while talking about the Tundra engine. He actually says that they make small improvements to the engine to improve its efficiency, but they don't talk about it because it didn't change the torque or horsepower. The segment I am referencing starts at 1:58:
    https://www.youtube.com/watch?v=vsQ4tHIThs4
  24. May 15, 2019 at 8:04 AM
    Those small changes to improve fuel economy could be all in tuning maps. This would be most likely, since this is cheap to change (not cheap to test) and implement.
    Reminds me of all the complaints of the 2nd gen Tundra aggressive throttle. The 3rd gen addressed some of those issues and made the fuel pedal feel more linear. Then people complained about lost power.
    Fuel delivery and torque management can really change how a vehicle feels. Look at the new Cummins 6.7L diesel motor in the Ram. 1000 pound ft of torque. We all know maximum HP/TQ is not released at 1000-1400 rpm.
  25. May 15, 2019 at 8:09 AM
    Ronin73
    Ronin73 New Member
    And what I said could be what was changed...we don't know. My point to the other poster was that Toyota does make small changes to the engine throughout its life without publicizing it. There is no reason to believe that tolerances could not have been tightened and/or some other changes, therefore prompting the engineers to spec 0w20 in addition to helping with cafe standards. He tried to claim they wouldn't do that. My point still stands about the 0w20.
  26. May 15, 2019 at 8:20 AM
    For sure. Only speculation at this point.
    It would be interesting to see the middle eastern specs for the 200 series land cruiser with the 3UR-FE.
  27. May 15, 2019 at 8:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If I was on my home computer I would look faster.
    But going to castrol’s International sites and looking up European land cruiser 5.7 it calls for 20w-50.
    Would be interested to search more
    ColoradoTJ likes this.
  28. May 15, 2019 at 8:28 AM
    Is that for the Direct injection motor or VVT-i series though?
  29. May 15, 2019 at 8:29 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If a 5w or a 0w screws this motor up I’m headed for a lifted f150 ! Lol
  30. May 15, 2019 at 8:32 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Ronin73 swinging swords, yo!
    Bradyu123 likes this.
