Toyota Oil Filter and crush washer
Discussion in '2.5 Gen Tundras (2014-2021)' started by millerstone, May 19, 2017.
  1. May 19, 2017 at 9:12 AM
    millerstone
    millerstone [OP] New Member
    2017 TRD Pro DC Cement
    Hi guys, probably a dumb question, but I was looking at my Toyota oil filter and saw a couple O-rings and a blue crush washer/gasket thing. I know the O-rings go on the oil filter housing, but does the crush washer go on the oil drain plug or the filter housing bolt? When I changed my oil neither had a washer, but the fumoto valve I replaced the plug with had one. Just wondering if I should pull the filter housing bolt off and chuck the washer in there or if I'm all good.
  2. May 19, 2017 at 9:17 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's for the drain plug.
    OR18TRD, 15whtrd, Bear and 1 other person like this.
  3. May 19, 2017 at 9:18 AM
    millerstone
    Right on thanks man. That's what I figured but I wanted to be sure. Wonder why they don't come with one from the factory?
  4. May 19, 2017 at 9:41 AM
    Yeah i did my 1st oil change on my own when buying filter at dealership they said had to buy blue crush washer separate?!? WTF?!?!
  5. May 19, 2017 at 10:24 AM
    millerstone
    Really? Weird, my filter came with one. It was just loose in the box though, maybe the dude I bought it from hooked me up. I thought it was weird that the blue crush washer wasn't on my oil drain plug from the factory. Just metal on metal.
  6. May 19, 2017 at 11:08 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
  7. May 19, 2017 at 11:10 AM
    millerstone
  8. May 19, 2017 at 11:37 AM
  9. May 19, 2017 at 11:40 AM
    Also check out Fumoto valve replaces drain plug its a valve less mess fumotovalve.com also ther is another valve i forgot who posted the link..but after you remove the filter screw cap this valve screws in n it has a tube less mess when draining oil from filter
    RussellVaughan likes this.
  10. May 19, 2017 at 11:42 AM
  11. Sep 9, 2018 at 5:03 PM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    Quick question on the blue crush washer? Is the felt/fiber that’s adhered to the aluminum susceptible to outside chemicals; such as glass cleaner, gunk, pressure washer with soap. Just curious if there is anything to stay away from when detailing that area. My first post, so I look forward to reading up on here
    Pudge likes this.
  12. Dec 11, 2018 at 2:21 AM
    rodm1
    rodm1 New Member
    You should be fine. Anyone have the torque for drain plug?
  13. Dec 11, 2018 at 3:36 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Maplewood Toyota sells oem oil filters buy four get one free. Been that way for at least ten years. They give you all the crush washers you want for free. Good luck. D
  14. Dec 11, 2018 at 4:56 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Don’t quote me on this, but I wanna say 30 ft/lb for the drain plug.
    I know the filter housing is 18ft/lb...and the filter drain cover is 9.
    OR18TRD likes this.
  15. Dec 11, 2018 at 7:04 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    My Toyota dealer sells the filters for a good price and the parts guy puts a drain plug washer in the box with each filter.
    FWIW, if you take out the drain plug and do not find a washer, make sure that one is not stuck to the oil pan where the plug came out.
    OR18TRD likes this.
  16. Dec 12, 2018 at 2:47 AM
    rodm1
    rodm1 New Member
    That is what I'm thinking but seems high!
  17. Dec 12, 2018 at 3:34 AM
    Bear
    Bear
    Custer, SD
    Damn it!!! And I saw that coming too!
    OR18TRD[QUOTED] likes this.
