Toyota OEM LED headlight warranty question
Discussion in 'Lighting' started by nodak67, Jan 2, 2018.
  1. Jan 2, 2018 at 1:53 PM
    nodak67
    nodak67 [OP] New Member
    JR
    so does anyone have any idea if the oem Toyota led headlights are considered a wear item or are they a component item that falls under the standard warranty replacement (or the platinum extended warranty)?
    since we are no longer dealing with a physical bulb that you can replace yourself.
    only thing I can find is that under VSA platinum additional exclusions section lists :
    "Lamps, Light Assemblies/Housings, and Light Bulbs"
    619Tundra likes this.
  2. Jan 2, 2018 at 4:52 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Good questions. I don't know how Toyota handles the LED light assemblies, on my last F-150 they were covered under the 3/36 warranty. Under the extended warranty there was an extra charge for those lights.
