Toyo MT’s drift to the right?
Discussion in 'Wheels & Tires' started by Zero One Actual, Nov 17, 2020.
  1. Nov 17, 2020 at 3:08 PM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I have new (400 miles on them) Toyo MT 285/75R18’s. They were installed at the local Four Wheel Parts shop (4WP). Alignment and balance done as well.
    As I drive I have to keep constant pointer finger and thumb pressure on the wheel to prevent it from drifting right. If I don’t do anything it takes about five to seven seconds at 65mph and the truck will be in the right lane.
    I called 4WP and was told that all the Toyo MTs they instal drift to the right. Ummm. Okay? So I said well if I swap fronts will it drift left and does Toyo know about this nation wide crisis? Anyways, before I take it back for a free alignment because the first one wasn’t done properly, has anyone else actually heard of this issue?
    Thank you.
  2. Nov 17, 2020 at 3:11 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Careful in the wrong combination you'll be stuck making tank turns unable to get anywhere.
  3. Nov 17, 2020 at 3:16 PM
    Zero One Actual
    Exactly. Toyo probably said “as a small unknown company it will benefit us if we make tires that go right. In Australia and Japan it kills everyone.
    Saltyhero13[QUOTED] likes this.
  4. Nov 17, 2020 at 3:26 PM
    Kanobi13
    Kanobi13 New Member
    Alignment numbers
  5. Nov 17, 2020 at 3:27 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Mine pull right but I highly, highly doubt it’s because of the tire. I think my alignment has gotten whacky but haven’t had time to check it again. Do you have your alignment sheet?
    Causes for pulling right:
    Negative camber on PS
    Less caster on PS than DS
    Perfectly even alignment with crown in the road sloping down on the right
  6. Nov 17, 2020 at 3:48 PM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    We ran them on several trucks through the years & everyone of them pulled to the right.
  7. Nov 17, 2020 at 4:17 PM
    Blue Thunder
    Washington
    Well hell...scratch those tires from my list.
  8. Nov 17, 2020 at 4:18 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Mine didn’t pull right for the first 100+ miles after alignment but then some wacky things happens and I can almost guarantee my camber is off and that’s what is causing mine to pull right. No tire should pull to one side or the other. That’s just silly.
  9. Nov 17, 2020 at 4:34 PM
    Zero One Actual
    How is this a thing? Hahaha.
  10. Nov 17, 2020 at 4:34 PM
    Zero One Actual
    I will have him send them via email and I will post them up. Probably not until tomorrow.
  11. Nov 17, 2020 at 5:18 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Had one set pull to the right on 3 different trucks. Also had a set of St Maxx that did the same thing. I run the first 20k on my Tundra and then swap them to my wifes FJ and then to my work truck to run them bald.
  12. Nov 17, 2020 at 5:23 PM
    pickeledpigsfeet
    Kings & Icons
    Just google toyo mt pulls to the right and tons of threads with the same issue.
  13. Nov 17, 2020 at 5:58 PM
    TheBeast The Beach
  14. Nov 17, 2020 at 6:44 PM
    Zero One Actual
    Well I am glad I posted this question first rather than being upset at the 4WP person. I will still get the alignment specs to see if there is anything I can tweak to combat it a little bit. I do still love the tire though so far.
  15. Nov 18, 2020 at 5:34 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Hopefully 4WP didn't sell you the tires. I be more than slightly annoyed if they sold me tires with a know issue.
  16. Nov 18, 2020 at 5:58 AM
    Zero One Actual
    Yes they did. And they did the instal and alignment. Hence my original post asking the forum if this is a known thing (which it appears to be) before I go over there and dig deeper into what can be done, if anything.
  17. Nov 18, 2020 at 7:05 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I need a raise too but they are already paying me more than I'm worth. Would be nice to get bumped up to $4 an hour this year. :yes:
    Zero One Actual[OP] likes this.
  18. Nov 19, 2020 at 11:18 AM
    Zero One Actual
  19. Nov 19, 2020 at 11:22 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Interesting that they would pull consistently to the right, but I acknowledge it seems like a know. Issue with the MTs on multiple sites. Bummer, I was seriously considering these as my next set of tires. Scratch those from the list.
  20. Nov 25, 2020 at 9:17 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have a set of MTs with less than 100 miles on them. They were pulling to the right before the alignment and after the alignment. Tech cross swapped the fronts and no more pull. My alignment specs are right on. I drove it around at highway speeds about 30-40 miles and can't notice a pull.
