Toyo A/T IIIs installed - 285 75 18 stock wheels
Discussion in 'Wheels & Tires' started by wiretwister, Jul 8, 2020.
  1. Jul 8, 2020 at 3:59 PM
    wiretwister
    wiretwister [OP] Sorta new guy
    NJ
    '22 SR5 CM
    Finally got my Toyo Open Country A/T IIIs installed.
    285-75-18 on stock TRD off-road 18" wheels. No spacers - stock 60mm offset
    Suspension is: Bilstein 6112s front set at 1.9" with 1 Coachbuilder spacer on passenger side and 2 on driver side. Rear is 5160 with Coachbuilder +2 shackles. It's about as level as you're going to get with a full tank of gas and ~100lbs worth of crap in/on the bed.
    Removed front flap thing = NO RUBBING ANYWHERE
    These replaced the stock Michelins.
    This size is slightly taller than most 35s at 34.8" dia. vs 34.5" for a '35' and about 3/4" narrower. It shares the same 3-ply sidewall and the same casing as the 35s.
    Observations:
    More comfortable over small bunps and hard-edged road imperfections. Definitely more isolated and insulated feeling, however I do feel like more disruption is sent to the rear and bed wiggle is slightly more prominent. You can definitely feel the increased weight in the steering wheel and the truck lost some responsiveness in the power department.
    Handling is actually better, which can be attributed to the stiffer sidewalls. At cruising speeds the on-center feel through the steering wheel is better and the truck 'floats' over expansion joints and big whoops much nicer compared to the stock tires.
    Highway noise is obvious and above 60mph creates a decent whirling noise.
    Overall, I'm really liking everything so far and I got an insane family hookup on the price, so that's great.
    The last picture really shows how much beefier they are versus stock tires.
    107724565_10101712416370949_220593254675_a35699732e5369d7e4c01f12412fdf374bed74d5.jpg
    107896191_10101712416425839_808352911539_045ae3bf77c6a1c29dfc86b41834a9976cc12a0c.jpg
    106469987_10101712416620449_504890027913_bd0b890e17735f987d36cc496c196fba4c476ed5.jpg 106707107_10101712416665359_126644645157_067082a1dc3e1a226ea3221ae237c2bb95a1f64a.jpg 106551369_10101712416994699_152942074060_071c2a25a21fb1a14f21a17f0729a21e85262be4.jpg 107044735_10101712417049589_313224274281_d30bca425ee9e1eb91424295a9e678c6ae7c9c11.jpg 107710245_10101712417244199_142992885062_7c27a1ff2ac5c919e0da3e48ed6c0fda7d6a5d5b.jpg
    MickeyStine, RRR1C0, Paul B and 12 others like this.
  2. Jul 8, 2020 at 4:03 PM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    any A/T should be better....the stock Michelins are a joke compared to anything else lol idk why toyota puts them on the PROs.
  3. Jul 8, 2020 at 4:51 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Are you leveled out in the front? Hard to tell by the pics
  4. Jul 8, 2020 at 4:55 PM
    wiretwister
    NJ
    '22 SR5 CM
    Sorry, yes. I totally spaced on adding that piece of info to my original post. Bilstein 6112s front set at 1.9" with 1 Coachbuilder spacer on passenger side and 2 on driver side. Rear is 5160 with Coachbuilder +2 shackles. It's about as level as you're going to get with a full tank of gas and ~100lbs worth of crap in/on the bed.
  5. Jul 8, 2020 at 5:19 PM
    19crewmaxTRD
    Seth
    That’s basically the same setup I’m getting installed. I’ve been going back and fourth on tire size, thanks for your post trucks looks great
  6. Jul 23, 2020 at 6:49 AM
    COTundra23
    COTundra23 New Member
    Thanks for posting this. I have the same suspension setup and had been curious if the 285/75 would fit on the 1.9" setting. Do you think I could get away without the shims or were the shims necessary? I am wondering if I would be better off doing shims on 1.9" or just bumping them up to 2.5" (top setting). Did you explore that option by chance?
  7. Jul 23, 2020 at 6:55 AM
    wiretwister
    NJ
    '22 SR5 CM
    on stock 18" 60et wheels I have a little bit of clearance from the front fender well liner as well as the body mount. I think it's likely that even on the 1.9" setting you'd have clearance, but I couldn't say for sure. I didn't install the shims so I could clear the tires, I installed the shims to get more height without going to the top setting and further increasing the preload (which seems is still up for debate as to whether you're actually increasing the preload)
    COTundra23[QUOTED] likes this.
  8. Jul 23, 2020 at 6:58 AM
    COTundra23
    figured that would be the case. thanks for the feedback. guess i will just have to give it a try for myself!
  9. Oct 8, 2020 at 7:01 PM
    biebs96
    PA
    Not that old of a thread, so I don’t feel that bad at bumping it..
    but my local tire shop has 285/75/18 in stock in the tire I want..
    these will fit on a leveled (on 5100 middle setting) with factory TRD wheels, without and trimming? Seems all the research I’ve done says yes!
  10. Oct 8, 2020 at 8:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks great with all that sidewall!
  11. Oct 9, 2020 at 8:57 AM
    betotundra
    betotundra Toyota for Life
    Great post, thank you!
    This is my prefered size in the event of me upsizing from the OEM size.
    However, more than the rubbing other things concern me a little, like loss of thin pedal response, sluggish acceleration (specially from stop), and the potential need of regearing.
    Any comments on these subjects by the OP?
  12. Oct 11, 2020 at 7:19 PM
    wiretwister
    NJ
    '22 SR5 CM
    Regearing would be more of a luxury at this point. I don't feel like I've lost much oomf from the truck. It's not quite as lively off the line, but the difference I felt right after the tires were installed has since faded and I really don't notice it anymore.
    Tundra_361, 406Michael, drobb and 2 others like this.
  13. Oct 23, 2020 at 6:52 AM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    You won't notice any significant power loss running the 285x75 it's not as heavy as the 295/70 and 35x12.50
  14. Jun 27, 2021 at 12:00 AM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    Tow haul mode fixes the power loss problem
    :burnrubber:
    wv_tundra likes this.
  15. Jun 27, 2021 at 12:02 AM
    AlaskanAssassin
    David
    Alaska
    Still loving your setup? I’m doing this exact setup but with CB +3 shackles.
  16. Jun 27, 2021 at 5:34 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    kind of but not really. What it does is hold the shifts longer, since the taller tires cause the transmission to shift too soon. So tow/haul mode just gets you closer to normal. I know one comment on here was old, but 285/75 weighs the same as 295/70. The tires are roughly equivalent, one is slightly taller one is slightly wider
  17. Jun 27, 2021 at 1:32 PM
    808Guy
    808Guy New Member
    Midwest
    2020 White Tundra SR5 CrewMax
    3" ReadyLift
    I have the same setup too. I like it but have contemplated about changing it up with Method wheels.
  18. Jun 27, 2021 at 2:29 PM
    BayRunner
    2017 Tundra Platinum
    A Bullydog tune will take care of that. I run 295/70R18 Toyo ATIII with a tune and it is very preppy and shifts very smoothly.
  19. Jun 27, 2021 at 2:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    i run a bullydog too. It cleans up the shifting a ton, still does not compensate for the tire height. The ratio of rpm/mph is different when you change tire height, thats what messes with the shifting. Im not saying the tundra is undrivable with bigger tires, it is just not the same
  20. Jul 3, 2021 at 5:05 AM
    wv_tundra
    wv_tundra New Member
    Almost Heaven
    2017 Inferno Tundra TRD DC
    Blacked out Badging, 3" Lift, Toyo 295/70 Open Country ATIII's
    36EC06AA-D7CD-4E54-BA59-9CCF3D617F08.jpg 295/70 OC ATIII on stock TRD Off Road rims. Leveling kit installed is 3” front 1.5” rear.
    AlaskanAssassin likes this.
  21. Jul 3, 2021 at 9:08 AM
    AlaskanAssassin
    David
    Alaska
    BMC or fender mod needed?
  22. Jul 5, 2021 at 4:17 AM
    wv_tundra
    Almost Heaven
    Only mod was having the small mud flap removed at the front tire
