Towing
Discussion in 'Towing & Hauling' started by Scarecrow, Nov 26, 2016.
  1. Nov 26, 2016 at 5:46 PM
    Scarecrow
    Scarecrow [OP] New Member
    Zack
    06 Tundra SR5 4.7 v8 4x4
    Ok so I'm pulling a tailor with a Harley on it through the mountain passes tomorrow. Do i need to turn OD off? Mac load is about 700 lbs and that is on the high, high end i would say bike and trailer are about 500 lbs.
  2. Nov 26, 2016 at 6:30 PM
    You know, a tailor fit suit is hard to find, let alone a tailor. I would suggest not pulling your tailor behind your truck.
    Ha, just busting your balls. If the transmission starts hunting for gears, take the truck out of OD. Your load with the trailer is propably 1000-1400 lbs.
  3. Nov 26, 2016 at 6:38 PM
    Scarecrow
    Zack
    I so hate auto correct. I swear it is a curse! :mad:
  4. Nov 26, 2016 at 6:40 PM
    LMFAO. No doubt.
  5. Nov 26, 2016 at 7:27 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    Whenever I'm pulling a long grade, whether towing or not, I turn od off. Transmission stays cooler.
  6. Nov 26, 2016 at 7:38 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I always use tow mode when i pull a trailer.
  7. Nov 26, 2016 at 7:52 PM
    He has a 1st gen Tundra
  8. Nov 26, 2016 at 8:01 PM
    Scarecrow
    Zack
    Yeah i was going to say it does have the towing package installed on it though.
    ColoradoTJ likes this.
