Towing
Discussion in 'Towing & Hauling' started by Icecreamman, Dec 12, 2023.
  1. Dec 12, 2023 at 10:36 AM
    Icecreamman
    Icecreamman [OP] New Member
    Hi all. I have a 8000 pound boat and trailer combined. Can a new tundra tow that without a weight distributing hitch?
  2. Dec 12, 2023 at 11:38 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    What's the tongue weight? I'm less familiar with boat trailers. I know they tend to have lighter tongue weights than the travel trailers that I am familiar with. Do they make WDHs for boat trailers?
  3. Dec 12, 2023 at 11:42 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    If the load weighs more than the tow vehicle get a weight distribution hitch. It will help stabilize the load. Disconnect the spring arms before you back up.
    j-utah, GODZILLA and Icecreamman[OP] like this.
  4. Dec 12, 2023 at 11:55 AM
    AZBoatHauler
    So.Arizona
    Boat trailers typically utilize surge brakes not designed to be used with a WDH. The truck should tow that load fine - my boat is about 1,000 lbs lighter on the trailer and I go up and down 8% grades without any trouble.
  5. Dec 12, 2023 at 12:26 PM
    Icecreamman
    I’m going to have to take it to a scale.
  6. Dec 14, 2023 at 10:22 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    It won't be fun but it can be done.
  7. Jan 20, 2024 at 6:36 PM
    Tundra2Seater
    Tundra2Seater New Member
    Thomas
    2012 Tundra 4x4 5.7L reg.-cab bucket-seats short-box black beauty
    I tow with a 2012 regular cab short box with 22" Black Rhino wheels and low profile streets, and pull a 29' RV (34'9" overall) dry weight 7400 lbs. (always travel with 1/2 tank of fresh water because I often boondock). I use a load-levelling anti-sway device with two 1,500 lbs. torsion bars. In addition, I have a Subaru 3200 watt inverter in the box, firewood, equipment, etc. I've towed a lot of RVs over the years, including a 30' RV that I pulled for 7 years in Canada and the US with a 2003 4x4 Durango with the 4.7 L (lovely engine). With the Tundra in this configuration I've never felt that I was overloaded, whether on divided highways or county roads. Great truck.
  8. Jan 20, 2024 at 6:52 PM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Nice. You running air bags with that?
  9. Jan 20, 2024 at 7:01 PM
    Tundra2Seater
    Thomas
    No air bags.
