Towing
Discussion in 'Towing & Hauling' started by Ray ramirez, Mar 7, 2023.
  1. Mar 7, 2023 at 5:10 PM
    Ray ramirez
    Ray ramirez [OP] New Member
    Raymundo
    Tundra 2016 crewmax sr5 5.7 lit
    Rear airbags and swaybar
    Can I tow a 28ft long,travel trailer 6300 lbs with my tundra 2016 crewmax? I have a 5.7 lit and just installed rear aairbag.Thank you
  2. Mar 8, 2023 at 12:28 AM
    Retired...finally
    Drats. In a world where people look at life in either black or white people like You and I let them know there are many different shades of gray as well as a complete rainbow of colors.
    Yeah Raymundo, things aren't as simple as a yes or no. BTW, did your truck come with the towing package?
  3. Mar 8, 2023 at 5:37 AM
    Ray ramirez
    Raymundo
    Yes It has towing package and I just want to know if is safe for my truck to tow. And it's my wife,me and my 2 young daughters. I also never do dry camp therfore I don't fill my fresh tanks at all ,all my tanks are empty.
  4. Mar 8, 2023 at 6:05 AM
    Retired...finally
    This a few of @Mattedfred questions need answered. If there is a scale near you weigh your truck as it will be loaded for your trip. Full fuel too. Subtract that weight from the GVWR shown on the door jam sticker. Subtract an additional 100 pounds from number and you will have maximum tongue weight your Tundra can carry. Example: GVWR is 7,200#. The scale reads 6,400 fully loaded. This gives you 800 pounds of additional cargo. Subtract 100 for the weight distribution hitch if it wasn't installed already for the scale weigh and this leaves you 700 pounds for tongue weight. If and that's the key word, if you can load your trailer to achieve the magical 10% tongue weight you will just barely be able to pull a 7,000# trailer. Problem is many trailers are built nose heavy and care must be taken to get some weight moved to the rear.
    Is the noted length of the trailer for the living space or total length from hitch to bumper? It it's living space you may not like how it handles especially if you are close to the 10% tongue weight.
  5. Mar 8, 2023 at 6:23 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Can you pull the load? Yes. Can you do it safely? Depends on a whole bunch of variables. Larger trailers act like sails & the wind might whip you around. Are you going to haul it up into the mountains? In what weather conditions? On what type of road surfaces? How fast are you planning on driving? Do you have a transmission cooler? Does the trailer have trailer brakes? Go look around at various camp grounds and see what set ups other people are using. I rarely see a 1/2 ton truck towing a large trailer. Bigger truck means more control.
  6. Mar 8, 2023 at 9:52 AM
    Ray ramirez
    Raymundo
    Thank you very much this helps and yes my trailer says it's 6250 lbs and I do have a transmission cooler.
    RCwyoming likes this.
  7. Mar 8, 2023 at 10:14 AM
    CTundraForMe
    CTundraForMe New Member
    I'll echo what the others have said.
    You need to determine your payload. You need to have a weight distribution hitch. You need to configure your brake controller correctly.
    You need to be careful and do your research and practice somewhere safe before you hit the road.
    BravoDeltaRomeo likes this.
  8. Mar 8, 2023 at 10:24 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Is 6250 is your dry weight or GVWR?
  9. Mar 8, 2023 at 10:26 AM
    Ray ramirez
    Raymundo
    Thank you
