Towing with Gen1 2005 Tundra
Discussion in 'Towing & Hauling' started by 2angle, Aug 27, 2019.
  1. Aug 27, 2019 at 12:17 PM
    2angle
    2angle [OP] New Member
    2005 Access Cab
    Getting ready to pull a 1,000 pound boat on a 500 pound trailer to the Florida Keys from New Jersey. 1,200 miles in all. I have a 5 speed auto trans. It seems unrealistic to drive at highway speeds for 1200 miles without overdrive.
    Can I get away without using towing mode with a 1,500 pounds in tow without doing damage to the trans?
    Or should the towing mode be used?
    Advice appreciated.
  2. Aug 27, 2019 at 12:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I towed in D with my gen 1 on flat ground. Any hill section and i put it back to 4th gear.
  3. Aug 27, 2019 at 12:29 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you have a way of monitoring your trans temperature?
    tvpierce likes this.
  4. Aug 27, 2019 at 1:20 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I used to tow a pair of watercraft, probably 2,000 lbs+ with my 2001 4wd AC. I usedOD on the flats & out of OD on the hills. Never any issues.
  5. Aug 27, 2019 at 3:15 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    You will be fine. 1500lbs is nothing and that truck will barely feel it!
    tvpierce and mscribellito like this.
  6. Aug 28, 2019 at 5:07 AM
    2angle
    2005 Access Cab
    Now way to monitor trans temp. Thanks for the input. Feel better about now and use tow mode when needed and overdrive on the straight of ways.
  7. Aug 28, 2019 at 6:19 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  8. Aug 28, 2019 at 6:24 AM
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
