Towing with a Platinum
Discussion in 'Towing & Hauling' started by Lord Ozi, Mar 1, 2023.
  1. Mar 1, 2023 at 7:56 PM
    Lord Ozi
    Lord Ozi [OP] New Member
    Anyone have any experience towing a 7500lb or higher travel trailer with their 3rd gen platinum Tundra? How do you have your WDH setup with your air bags? What WDH system are you running? Lastly, have you had any problems distributing weight to the front axles. If this topic has been discussed already, if someone could repost the link that would be great.
    Thanks,
  2. Mar 8, 2023 at 10:58 PM
    CarJon
    CarJon New Member
    2022 CrewMax Blueprint Platinum Tundra 4x4 (5.5 ft bed)
    1.75 in front level / Nitto Recon Grappler A/T - 295/60R20 on stock wheels.
    Getting ready to tow something this weekend, will let you know what the weight etc. is... A three hour tour... a three hour tour... Not sure if hitting the 7.5k mark or not...
    More to follow...
  3. Mar 9, 2023 at 8:25 AM
    Lord Ozi
    Thanks. My initial test was not very good and I did not have time to tweak my setup before I left. As a result, the weight distribution was not working properly and I had almost 2 inches of lift in the front which made for a very unpleasant and floaty 3 hour drive.
    Hbjeff likes this.
  4. Mar 9, 2023 at 8:50 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  5. Mar 9, 2023 at 8:24 PM
    Lord Ozi
    Thanks for the link. I spent a good hour or so reading through it. There is a wealth of information on there! I was more interested in knowing how others are towing with the same truck configuration as mine and what their experiences were--particularly with distributing more weight to the front axles.
    Cheers,
    Melikeymy beer likes this.
  6. Mar 10, 2023 at 6:58 AM
    Melikeymy beer
    Muscogee Nation
    Are you using a weight distribution hitch? You should be able to level the truck using the hitch and it sounds like maybe shifting trailer weight from back to front where possible.
    GODZILLA likes this.
  7. Mar 10, 2023 at 7:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    you'll need bags.
    I tow 6k lbs, and it sags pretty good. I installed firestone bags with cradles and no problems.
  8. Mar 10, 2023 at 7:12 AM
    He has a 3rd Gen, so different suspension setup than yours. Unless your profile is wrong.
  9. Mar 10, 2023 at 7:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ohh, i didn't catch that he's a 3rd gen.
    I'd still imagine its valid with that weight...i assume he doesn't have the air suspension, or wouldn't be talking about the squat.
    KNABORES[QUOTED] likes this.
  10. Mar 10, 2023 at 9:10 AM
    Melikeymy beer
    Muscogee Nation
    I pull a 6k lb trailer with my truck and original suspension and no bags are necessary with a properly adjusted WDH. Even without my WDH it's close to level. Each case is different.
  11. Mar 10, 2023 at 5:39 PM
    Lord Ozi
    Thank you all for your replies. The Tundra does have air suspension--though you can't control the psi and my WDH is clearly not disturbing the weight properly with the added air suspension. The sqaut is non-existent, it's the corresponding lift in the front that is messing things up. I have since added more spacers to my hitch to see if that resolves the problem (haven't retested yet). I was just wondering if anyone else has had this issue with the new tunny air suspension and what they have done. I should also mention that I've used this same setup with a 2014 SR5 TRD pro with no problems--but it didn't have air suspension.
    Thanks,
  12. Mar 10, 2023 at 5:42 PM
    Lord Ozi
    I should probably also mention I'm towing an 32ft 8k TT.
  13. Mar 17, 2023 at 4:11 AM
    Retired...finally
    Yeah but we have that big honking V8 up front to help.
  14. Mar 17, 2023 at 8:03 AM
    Melikeymy beer
    Muscogee Nation
    It always gets a kick out of comments about the 5.7 being a big engine. It's the same size as the 350 ci engine was in my 1972 Monte Carlo and we had a Pontiac sedan with a 455 ci engine. The 5.7 does produce a lot more power though.
  15. Mar 17, 2023 at 8:07 AM
    To be fair, it is a physically large engine compared to pushrod GM V8's, displacement aside.
  16. Mar 17, 2023 at 8:18 AM
    Retired...finally
    I think the GM 350 came equipped with lugs to tie the boat anchor rope.
  17. Mar 17, 2023 at 8:21 AM
    GM LT5 350ci motor made 405hp. in 1994.......
  18. Mar 17, 2023 at 11:28 AM
    Melikeymy beer
    Muscogee Nation
    Hey, it could move pretty good! It was exhausting trying to keep it tuned tho, lol. It's funny reading people on here talking about "reliability" problems with modern cars. I always think back to spending a weekend every other month wrenching in the garage trying to keep my jalopies rolling.
