Towing up to 10,300 lbs with 4.10 gears?
Discussion in 'Towing & Hauling' started by Seadawg1, Feb 1, 2017.
  1. Feb 1, 2017 at 2:25 PM
    Seadawg1
    Seadawg1 [OP] New Member
    Larry
    Northwest
    2017 Gray Toyota Tundra, DC, SR5, TRD PRO
    I have a 2007 Tundra Double Cab, 5.7 engine, with tow package. But the gears are 4.10 (I think the .10 is correct) I was told that it would tow 10,300 lbs no problem. I was told this 2 years after I bought so that did not have an affect on my purchase. So with 4.10 still allow to tow that much? I tow about 7600 gvw Travel Trailer. thx
  2. Feb 1, 2017 at 2:33 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You will be fine with your truck pulling that trailer
    Rocket75757 and Bob like this.
  3. Feb 1, 2017 at 2:47 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you have tow package, I believe you should have 4.30.
  4. Feb 1, 2017 at 2:48 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hmm not sure
    That is what I was thinking too. Pretty sure the 4.10 is only in base non towning package tundras.
  5. Feb 1, 2017 at 6:49 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I have two package and have 4.30
  6. Feb 1, 2017 at 6:57 PM
    Do you go into the mountains a lot? If you do,that might be your deciding factor. I would try it out first, since if you need a bigger truck, you will need all the same equipment like a LDH.
  7. Feb 1, 2017 at 7:09 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Rocket75757 likes this.
  8. Feb 2, 2017 at 10:29 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  9. Feb 2, 2017 at 11:52 AM
    Factory tow package with the 4.3s.
