Towing sag handling improvements
Discussion in 'Towing & Hauling' started by GregoryDavid, Nov 6, 2019.
  1. Nov 6, 2019 at 1:35 PM
    GregoryDavid
    GregoryDavid [OP] New Member
    2011 5.7 crew max
    Is there anything I can do to stop the sag I get when towing? Leaf springs or something? Also to help with handling?
  2. Nov 6, 2019 at 1:40 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Airlift or Firestone air bags, easy installations, and options for on-board air to adjust pressure.
    Bigboitundra and 08crewmax like this.
  3. Nov 6, 2019 at 1:40 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    How much are you towing?
    GODZILLA and ColoradoTJ like this.
  4. Nov 6, 2019 at 3:01 PM
    GregoryDavid
    2011 5.7 crew max
    7500ish lbs.
  5. Nov 6, 2019 at 3:51 PM
    Radial GT
    Radial GT New Member
    Northern MN
    2019 Limited TRD CM
    Leveled, bagged camper hauler
    I have Firestone bags. Love them for towing the camper, hauling the 4wheeler in the bed, and unloaded rode.
    Bigboitundra likes this.
  6. Nov 6, 2019 at 10:01 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Assume you are referring to rear end sag.
    If not already installed, a Weight Distribution Hitch is a must for that kind of weight. If one is installed, it needs to be properly adjusted to equalize the weight so your truck remains level (but will have sag at all four wheels). Easiest way to adjust is to measure distance to the top of all four wheel wells unhitched and then after hitched and weight distribution bars have been set. All four wheels should have the same drop, adjust until they do.
    Air bags are not a replacement for a properly adjusted weight distribution hitch.
    Greg
    MrMax, Sp33dNut, Fosterscout and 2 others like this.
  7. Nov 6, 2019 at 10:12 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Air bag, sumo spring, timbren, super spring, hellwig spring, AAL.
    Take a pick...
