Towing MPG
Discussion in 'Towing & Hauling' started by Sombra, May 15, 2019.
  1. May 15, 2019 at 11:35 AM
    Sombra
    Sombra [OP] New Member
    Cam
    2018 Superwhite Tundra
    I have a 2018 Tundra Limited, pulled a small trailer 17 ft weight 3700 lbs, getting 8 mpg in the rocky mountains of Colorado. I recently took a trip from Denver to Wichita with same trailer and got about the same mpg. I guess this is as good as it gets.
    Duneflyer likes this.
  2. May 15, 2019 at 11:43 AM
    Enclosed trailer?
    Seems a little low unless it’s an enclosed trailer.
  3. May 15, 2019 at 5:46 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Towing a 24 pondtoon tips out at 5500. With 35 inch tires and 6 inch lift getting 11-12 at 60mph
  4. May 15, 2019 at 5:47 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I agree that’s low
  5. May 15, 2019 at 6:22 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    With my 21ft travel trailer at 3200lbs I could only manage 10.3 on mostly flat highway so I could see 8 in the mtns. I to thought I would do a little better since my trailer doesn't weigh much but I guess the weight isn't a big factor once your cruising at speed.
  6. May 15, 2019 at 6:26 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Iam on all flat ground. I guess you guys with the campers is fighting the wind.
  7. May 15, 2019 at 6:29 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah that's what I'm thinking, mostly the aero that matters and not so much the weight.
    ColoradoTJ likes this.
  8. May 16, 2019 at 2:57 PM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    I pull my toyhauler, car trailer and a utility trailer. Speed is the biggest variable you can control. Every 5mph above 60mph cost me about 1mpg regardless of what is hooked up behind my truck.
    Duneflyer, MSU Tundra, Newm and 2 others like this.
  9. May 16, 2019 at 3:12 PM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    Towing a 6x12 Singel axel enclosed trailer with the 08 Sequoia or the 2017 Tundra 1794 No hills - No headwind = 9 MPG
    Towing a 7x14 dual axle enclosed trailer same vehicles 9 to 10 MPG
    Headwinds and hills can really affect your mileage into the 7 and 8 MPG area.
  10. May 16, 2019 at 3:53 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Dang guys. Glad I don’t pull an camper or enclosed trailer. That is crazy.
  11. May 18, 2019 at 9:38 AM
    Sombra
    Cam
    I love my Tundra and I used to own a 2002 chev 2500 hd with a 6.6L diesel. It actually gave me better gas mileage with a 27 ft HiLo trailer around 18 mpg.
  12. May 19, 2019 at 5:12 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    The bummer is the small tank at 10.3 my range towing my camper sucks, wish Toyota had the larger tank as an option across the board.
    My buddy has a 2012 2500hd just the 6.0 but it returns better mpg pulling his camper which is larger compared to mine. That's crazy.
  13. May 19, 2019 at 6:30 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I get 9.5mpg on level roads running 60mph and 8mpg at 75mph.
  14. May 19, 2019 at 6:58 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Boy, that's no joke. Seems like I cost myself more time at the fuel station if I try and hurry anywhere with my camper. I finally said to hell with it and do whatever speed it takes to get 10mpg.
    MrMax[QUOTED] and Watt maker like this.
  15. May 27, 2019 at 6:53 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Update went to a lake an hour away in tow mode interstate 20 miles then into to res lights every mile -two miles. Got 9 MPG. I think I stated earlier I was getting 11-12. That’s from my house to a smaller lake within 10 mins of my house. WOW!
  16. May 27, 2019 at 8:00 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I got about 6mpg pulling about 10k lbs (fully loaded) over Kenosha Pass this weekend for some dry camping at 10k feet elevation :eek:47817F3A-7830-4831-A724-3BADAC5627A5.jpg
  17. May 27, 2019 at 5:39 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Nice set up... truck looks great. what size of lift do you have??
  18. May 27, 2019 at 5:44 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I have a 7x12 older steel frame enclosed haulmark and ran the Pa. turnpike sat. To 7 springs resort for an ATV race and running 75-80 mph I got 11.2
  19. May 27, 2019 at 5:44 PM
    Midway
    Midway New Member
    Pulled my 19' Airstream up the California coast, averaging around 11-12 MPG, going around 55-65.
    Spartanfam and Coolhardy like this.
  20. May 27, 2019 at 5:53 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Tank size is big reason I got Tundra. 3 fill fill ups picking up my boat on 6 hour trip and I decided I needed a larger tank. Tacoma got the same 10 MPG at 65-70.
  21. May 27, 2019 at 6:14 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Thanks! 8” ReadyLift on 37’s
  22. May 27, 2019 at 6:27 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Did you re-gear or stock? How is the ride?
  23. May 27, 2019 at 6:37 PM
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    Deedub,
    Like your setup. How do the brakds hold up going over that pass or have you upgraded them. I tow a GD 2670MK 7000 lbs. empty 8500 fully loaded. Headed down to Mueller in a couple of weeks. Haven't towed over any significant passes yet but have read a lot about people having brake issues. Dealer didn't set my WD hitch correctly so I have worked on that. Will be picking the camper up in a couple of weeks for a short run so will see how the WD hitch is set now.
  24. May 27, 2019 at 7:03 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Yep, I have the nitro 5.29’s now. It still struggles but not as bad
  25. May 27, 2019 at 7:04 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I have stock brakes now but will not attempt that again without some brake upgrades lol. My pedal went soft half way through the trip and I puckered. Luckily my trailer has good brakes. To the dealer I go this week but guessing they’ll say I need more bite.
  26. May 27, 2019 at 7:07 PM
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    I pulled a 21' stratos bass boat from Kansas City to eureka springs this weekend going about 75mph the whole way and averaged about 10.5mpg on tow/haul. Also had a pretty strong head wind which didn't help
  27. May 27, 2019 at 9:30 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I can get as low as 6 mpg at times towing my dump trailer out here in MN. Then some days I'll get 10 pulling the same trailer on the same route.
    I average 11.7 pulling my flat bed.
    I've concluded that what direction the wind blows plays a big roll in what mpgs I get towing not just the grades I'm pulling up. It only took me 198k miles of driving this truck to realize this lol.
  28. May 27, 2019 at 9:41 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    How do u like your airstream? Thinking of getting either sport or nest but they are xpensive....
  29. May 27, 2019 at 9:51 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    You guys are making me feel good as I get 14 to 15 mpg when towing doing 60 - 65 my pop up on the high way. My pop up is about 2200 lbs, so I'm a light weight. This includes some mountain passes at 5500. I think the wind resistance is a major factor as well. Also some unimproved roads. 397572AB-23C1-48E3-BAA2-3E46329CA328.jpg
  30. May 28, 2019 at 2:19 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I get around 10-11 towing my jeep on the Flatbed total weight of trailer and Jeep is 5-6k in weight.
