Towing Mirrors
Discussion in 'New Member Introductions' started by Dbtoys, Jul 10, 2021.
  1. Jul 10, 2021 at 5:29 PM
    Dbtoys
    Dbtoys [OP] New Member
    Danny
    2015 Limited Tundra TRD Double Cab
    Newbie Here from Prineville Oregon.
    My Question is i have a 2015 Tundra limited double cab TRD the mirrors on it are power and heated.
    i need the trailer towing mirrors.
    can i add options to the mirrors?
    and will they be wired all ready?
    Thanks
    Danny B
    Prostar 190 and YardBird like this.
  2. Jul 10, 2021 at 5:40 PM
    Welcome from NY.
    You can get plug and play towing mirrors and you can even upgrade to turn signals and marker lights you just have to add some wires.
    Do a search for tow mirrors and you will see your options.
    Dbtoys[OP] likes this.
  3. Jul 10, 2021 at 5:54 PM
    Dbtoys
    Danny
    would you get the toyota mirrors or opt for the less expensive manufacturers?
  4. Jul 10, 2021 at 6:02 PM
    2mchfun
    Welcome here, I have the OEM, pretty good and I also added 3" Diameter Blind spots too because I really really like to make sure of what is going on around me. I don't let technology drive my vehicles. I have read both good and bad reviews of others.
  5. Jul 10, 2021 at 7:29 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Jul 10, 2021 at 7:55 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  7. Jul 10, 2021 at 7:58 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Adding OEM tow mirrors (or aftermarket) will give you the sidemarker/turn signal lights without additional wiring if my memory serves. I had OEM on my 2007 and like them. Due to the cost of the OEM, I went with ebay aftermarket oem-style mirrors. Fitment was poor and left a gap at the top of the mirror plate where it attaches to the door. I ended up returning them and stick with non-tow mirrors for now.
  8. Jul 10, 2021 at 8:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from up in WA.
    The OEM tow mirrors will be plug and play and will include turn signals and marker lights on the outer edge (amber LED) plus heat and power adjust.
    if you want puddle lights, rear facing flood lights, or power fold, you’ll have to go with after market and add some wiring of your own. If you just want in-glass turn signals in addition to marker /running lights, then look at after market lights that are plug and play.
  9. Jul 10, 2021 at 8:50 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. Jul 11, 2021 at 4:06 AM
    Welcome from Ohio
  11. Jul 11, 2021 at 4:39 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  12. Jul 11, 2021 at 5:05 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Welcome from Virginia.
    As others said, you’ll gain mirror blinkers & marker lights. OEM tow mirrors have heated & power adjust, too, but be forewarned, OEM tow mirrors do NOT have BSM. You have a limited, so do I. You’ll lose BSM If you buy OEM tows.
    I opted for OEM anyway because of the many many reviews I read about aftermarket mirrors (some of the aftermarkets do come with BSM functionality) being really crappy. Some said that on this thread. The majority of the bad reviews I’ve read for aftermarkets was for mirror shake at highway speeds. Makes the mirror blurred because it shakes so much.
    So I opted for the quality of OEM. There is a BSM mod that you can do for OEM tow mirrors, where you put an LED light in the sail panel on the window. I did that for my OEM tows and it worked out perfect.
    BSM mod thread:
    https://www.tundras.com/threads/bsm-and-oem-tow-mirror-mod.39092/
    And if you really wanna get fancy, you can add power-fold functionality to your Limited. A lot more wiring to do, but I did that as well and it worked out great. The power-fold tow mirrors are a lot more expensive though.
    https://www.tundras.com/threads/upgrading-to-power-fold-mirrors.12452/
    https://www.tundras.com/threads/auto-fold-mirrors-mod.5296/
    This guy did power fold & his write up was very helpful to me:
    https://www.tundras.com/threads/d3s-black-18-crewmax-tundra-build.31435/#post-776991
    Sorry for the “other site” reference, but this one was very helpful too from what I recall:
    https://www.tundratalk.net/threads/2014-power-fold-tow-mirror-install.566746/page-3
  13. Jul 15, 2021 at 11:06 PM
    Dbtoys
    Danny
    Thanks to All.
    I went with the Toyota Mirrors and could not be happier.
    No shake and a perfect fit the first time.
    Uhhhh.... likes this.
