Towing Mirrors on 17 Tundra
Discussion in 'Lighting' started by Uranium1960, May 19, 2019.
  1. May 19, 2019 at 1:08 PM
    Uranium1960
    Uranium1960 [OP] New Member
    Lyle
    2017 SR5 Tundra
    Body, Chassis, Interior, Lighting, Wheels & tires...
    I purchased power extendable towing mirrors for switch over on my 17 Tundra.
    They come with harness, front signal & running light, heat & power.
    NO folding or puddle lights. They do have tow Rear facing LED on each mirror which I can connect to Reverse or Interior / cargo lighting.
    I want to tap into signal light wiring and fab red tiny acrylic covers for rear facing signals.
    Ground is given but which color wire do I tap into for signal??
  2. May 27, 2019 at 9:29 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    I am thinking about getting the same mirrors for my 2017 Crewmax. Are these OEM? Can you send a pic of your rig with them on?
  3. May 27, 2019 at 4:13 PM
    Uranium1960
    Lyle
    2017 SR5 Tundra
    Sounds like I got same ones. I tested & taped into right & left signal and converted double Courtesy / Reverse light into rear facing signal then placed red len over them.
    here is hopefully picture attached. First time ive tried this on the forum??
    FYI Tip when testing mirror harness I used needle in each pin hole as tester was too large to fit tiny pin holes.
    Beesta and Watt maker like this.
  4. Jun 14, 2019 at 11:46 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Are these power folding mirrors .?
  5. Jun 14, 2019 at 4:17 PM
    Uranium1960
    Lyle
    2017 SR5 Tundra
    No not power folding, just power adjust, heat and signal.
    Took courtesy light and wired it to be rear red facing signal for lane changes.
