Towing mirrors OEM or ??
Discussion in 'Towing & Hauling' started by Cortez11, May 26, 2021.
  1. May 26, 2021 at 12:34 PM
    Cortez11
    Cortez11 [OP] New Member
    2013 DblCab 5.7 4x4
    Just took the camper out for the first time with the Tundra, it was very obvious right away that we need to upgrade our mirrors. Is it worth trying to find a used set of OEM Toyota mirrors, or are there better quality aftermarket mirrors out there? They've gotta be heated, and less than $300. Thanks.
  2. May 26, 2021 at 12:49 PM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
  3. May 26, 2021 at 12:54 PM
    Blue Thunder
    Washington
    I’m less than impressed with the OEM towing mirrors. They don’t provide enough viewing range. Both the main mirror and the “fish eye” are too small. Some of the aftermarket ones seem to vibrate, so do your research before buying.
    50Shades and mountainpete like this.
  4. May 26, 2021 at 12:58 PM
  5. May 26, 2021 at 2:28 PM
    Cortez11
    2013 DblCab 5.7 4x4
    Good to know, this is the exact info I'm looking for. Thanks man
    Blue Thunder[QUOTED] likes this.
  6. May 26, 2021 at 2:31 PM
    Cortez11
    2013 DblCab 5.7 4x4
    I had these for my Chevy and just wasn't a fan. I'd always forget to put them on before leaving the driveway, and we'd subsequently have to turn back around and grab them...the price is right though
  7. May 26, 2021 at 3:26 PM
    Get some Ram tow mirrors. Those mirrors are so far out they are in different zip codes.
  8. May 26, 2021 at 4:08 PM
    Cortez11
    2013 DblCab 5.7 4x4
    Haha that Tacoma(?) looks like a baby dumbo.
    ColoradoTJ likes this.
  9. May 26, 2021 at 4:34 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    GM style mirrors are out there. Boost auto I think has them, I got mine off eBay - search GM style Tundra mirrors. Best visibility by far over both OEM options.
  10. May 26, 2021 at 5:51 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    That is what I got and they’re perfect, although via Amazon. For some reason my order doesn’t show up on my history or I’d link to the specific item. Mine came with turn signal lights, heated mirrors, plug and play, maybe 30 minutes at most taking my time to install both of them.
    It always irritated me that the Tundra came with car-sized mirrors; it’s impossible to have them set correctly for driving and still use them to park in tight spots without leaning up against the window to look down. The new ones are better at everything except being out of the way when walking around the truck in those tight spots.
  11. May 26, 2021 at 5:56 PM
    I seen a set of dodge mirrors flipped up on a Honda Civic not long ago. It was amazing to see.
  12. May 26, 2021 at 5:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The Boost Auto chevy-style ones can check all your requests except maybe price (depends on the options you pick). I had the OEM ones on my 2008 and had no complaints - it came with them so I didn’t know any better. But now that I’ve got the chevy-style, there’s no comparison.
    Cortez11[OP] likes this.
  13. May 26, 2021 at 6:38 PM
    Cortez11
    2013 DblCab 5.7 4x4
    What makes the GM style that much better, they appear to be pretty similar. I came from a Duramax, but guess I don’t know what’s different about the Toyota style.
  14. May 26, 2021 at 6:58 PM
    belanger9
    Edmonton, AB
    A bunch
    Bigger is the main thing. Bigger top flat mirror for looking back, much bigger convex that lets you see your tire and the 2 lanes beside you.
    If you came from a duramax you will hate the Toyota tow mirrors. I preferred the small standard mirrors over their tow ones. They're too small and don't do anything well.
  15. May 26, 2021 at 7:08 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
  16. May 26, 2021 at 7:37 PM
    Cortez11
    2013 DblCab 5.7 4x4
    Perfect, that’s exactly what I’m looking for. Thanks for the input.
    Cg13055 likes this.
  17. May 26, 2021 at 7:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - exactly what he said. Bigger convex and bigger overall. I can see my rear tires in the convex AND the lanes beside me. Between that and the anytime front and rear cameras, I can park this thing anywhere it will physically fit
    Cortez11[QUOTED][OP] and RobertD like this.
  18. May 27, 2021 at 8:28 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I have the OEM mirrors and I'm very happy:
    - Very stable
    - Good viewing angle IMO, both the top mirror and the smaller curved mirror (I have the latter set to see my back wheel when backing up)
    - Heated
    - Has a blinker
    Those look nice. The OEM mirrors are pretty spendy.
    Tundra805 likes this.
  19. May 27, 2021 at 8:38 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    towing a air trailer lol
  20. May 28, 2021 at 2:23 AM
    hundytundy
    hundytundy New Member
    I'm a new Tundra owner, but did a lot of research, and if I can't live with the OEM mirrors, I'm going to try Boost Auto mirrors $$$ or Trail Ridge mirrors $$.
  21. May 28, 2021 at 2:52 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    We have the Trail Ridge and are very pleased. Also, if you break the convex there are replacement pieces out there that fit perfectly.
  22. May 28, 2021 at 8:27 AM
    Cortez11
    2013 DblCab 5.7 4x4
    Any idea how Trail Ridge match up against the Boost mirrors? I've been eyeballing Trail Ridge as well.
  23. May 28, 2021 at 12:46 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Not herd of Boost.
  24. May 28, 2021 at 12:50 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Another vote for OEM. They aren’t huge and IMO look more appropriately sized for a half-ton. I also don’t see any issues with the field of view so far, just as long as you line them up appropriately to view the SIDE of your vehicle and not behind you (that’s what the rear view mirror is for).
    Tundra805 and FlyingWolfe like this.
  25. May 29, 2021 at 5:20 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I use to have the Dodge ram style mirrors on my Tacoma. They worked very well. I sure wish someone would make them for the Tundra.
    thalgott3 and ColoradoTJ[QUOTED] like this.
  26. May 29, 2021 at 8:04 AM
    They work well. I just find it funny leaving them flipped up all the time.
    Cpl_Punishment likes this.
  27. May 29, 2021 at 8:12 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would buy them again in a heartbeat if they sold them for the Tundra.
  28. Jun 17, 2021 at 5:09 AM
    thalgott3
    thalgott3 New Member
    Colin
    2016 SR5 CrewMax
    I have the black/no signals on my 2013 and love them! I second your vote for a Tundra version so I can throw a set on my '16!
    Ruggybuggy[QUOTED] likes this.
  29. Jul 16, 2021 at 1:52 PM
    CaptCraig
    CaptCraig New Member
    Craig
    2021 Tundra CrewMax 4x4
    They're saying it won't fit my truck. :(
  30. Jul 16, 2021 at 8:57 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They will fit. 2021 is the same as 2020 and they fit mine. Amazon is wrong most of the time when it comes to fit and year.
