Towing long distance
Discussion in 'Towing & Hauling' started by Powder, May 29, 2017.
  1. May 29, 2017 at 3:55 PM
    Powder
    Powder [OP] New Member
    2014 Black Tundra CM
    Im in the process of moving and will have my boat with me. It will be about an 18-20 hour drive.. My biggest concern is making it between gas stations through no-mans land of Montana due to the Tundras pea size gas tank. Anybody else have any suggestions or lessons learned from a longer trip pulling something?
    ColoradoTJ likes this.
  2. May 29, 2017 at 3:56 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Buy gas cans. Multiple.
    Slidder, Metro14536, Law323 and 5 others like this.
  3. May 29, 2017 at 4:02 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    This. Get a couple 5 gallon cans just incase.
  4. May 29, 2017 at 4:14 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Yep bring extra fuel.
    Metro14536, 040Tundra and Powder[OP] like this.
  5. May 29, 2017 at 4:19 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    And dear god, get the cans that have the old style spouts on them!! Trust me on this one
    Slidder, Law323, CaptTyler and 3 others like this.
  6. Jul 13, 2017 at 10:21 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I just drove from Seattle to Boston (through Montana) pulling a 12k pound trailer with my 2008 Crewmax. It's got the rediculously inadequate 26 gallon fuel tank and I was getting about 7.5 mpg, but I never ran out of fuel between gas stations.
    I just made sure that I stopped at the next gas station once I hit about 140 miles since the previous fill-up.
    Here's me stopping for gas somewhere in North Dakota fully loaded.
    Before anyone lights their torches and gathers a mob because of that trailer weight, I made several upgrades before the trip, monitored engine and trans temps and drove very conservative speeds in 4th gear the entire 3,200 miles. The engine never came close to overheating, but the trans didn't like it when the torque converter wasn't locked up durring acceleration and hill climbs so I just slowed down until the trans temp held at 195-205°F.
    Air bags, swaybar, load range E tires, additional trans cooler, drilled and slotted rotors, ceramic pads, trailer brakes, weight distribution hitch and Water Wetter coolant additive. I was shocked by how stable it was pulling that much weight.
    I wouldn't recommend anyone doing it for fun, but I was in a big pinch and Toyota doesn't make a 3/4 ton truck yet. (Sorry folks, the Tundra is great, but it's still just a half ton truck.)
  7. Jul 14, 2017 at 4:02 AM
    You will be fine with one 5 gallon jerry can. Most issues in MT are in the winter with road conditions, sliding off the road, running out of fuel, and looking like a frozen chicken breast. When I was a young man in MT, my tank never went below 1/2 in the winter, and it saved me on more than one occasion.
    FYI, these cans are the best I have
    Ever used:
    https://autoplicity.com/1406285-vp-...WcF7LWtdjpjsE1TUSjyDAvLWw5jUUWJxoCC3oQAvD_BwE
    Powder[QUOTED][OP] likes this.
  8. Jul 14, 2017 at 4:28 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    When I had my Tacoma, I moved from MA to TX pulling a uhaul trailer. I bought 2, 5-gallon gas cans and strapped them in the bed. 9mpg with 21 gallons doesn't get you very far and I didn't want to risk running out of gas in the middle of no where. I ended up not using the extra gas, but I had piece of mind during the trip.
    like others have said.... get a gas can or two :)
    these are the cans I got... totally worth it:
    https://www.amazon.com/VP-Gallon-Sq...rd_wg=8R0lq&psc=1&refRID=WS1S5CWGX1XD4JABJFKE
    Powder[OP], Law323 and ColoradoTJ like this.
  9. Jul 14, 2017 at 4:50 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    Powder[OP] and ColoradoTJ like this.
  10. Jul 14, 2017 at 5:32 AM
    pbryant44
    pbryant44 New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    fill the boat full of gas then get a gas drain hose that way you can just take it out of the boat if you run low and if you don't then you have gas to go fishing.
  11. Jul 14, 2017 at 6:00 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    I had a 5 gallon Go Plus strapped in the bed of the truck when I had a trailer moving stuff from San Diego, Ca to San Antonio, TX. The only time I used it was when I helped a stranded motorist in Arizona on HWY 10 who had ran out of gas. I had enough gas from gas station to gas station.
    Powder[OP] and MotoTundra like this.
  12. Jul 14, 2017 at 6:43 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    This will work but...If you fill the boat tank you are hauling extra weight on your road trip and if you have never done it, getting fuel out of a boat tank can be a lot of trouble. (I live in a Hurricane zone and the 63 gallons in my Whaler is part of my generator fuel, so I speak from experience.) My advice is throw a 5 gallon can or two in the boat for insurance.
    Powder[OP], ColoradoTJ and MotoTundra like this.
  13. Jul 14, 2017 at 7:35 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I carry a can and use the Gasbuddy app to see the next station when approaching 150 miles.
  14. Jul 14, 2017 at 7:44 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    What kinda boat ya got there @Powder ?
    Powder[OP] likes this.
  15. Jul 14, 2017 at 7:53 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks like an x star, those are nice boats!!
  16. Jul 15, 2017 at 6:59 AM
    careyrob
    Carey
    Massachusetts
  17. Jul 24, 2017 at 6:51 PM
    Powder
    Thanks guys, made the trip in early June just fine, just annoying having to stop for gas so often...
    Moto, my boat is a 20' Reinell LXI. It has a 350 HP motor on it, you know, to make sure I don't get stuck in the water...... :rofl:
  18. Jul 24, 2017 at 7:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yeah, no one wants to get stuck due to low horsepower haha.
    Beautiful boat!
  19. Jul 24, 2017 at 7:32 PM
    How heavy is the boat? What kind of distance where you getting out of a tank? I was looking at 150 miles and at 200, it was time to pull out the old trusty 6 gallon fuel can.
