Towing larger trailers
Discussion in 'Towing & Hauling' started by jsmithtx, Sep 7, 2017.
  1. Sep 7, 2017 at 6:44 PM
    jsmithtx
    jsmithtx [OP] New Member
    Jimmy
    2008 Tundra
    Hi my name is Jimmy. I have a 2008 Tundra with the 5.7 engine. I have a 19 foot travel trailer I purchased. My Chevy with a 5.3 couldn't seem to pull it. That is when I got the Tundra. I'm thinking about a larger trailer or possibly a fifth wheel. Everyone told me I could pull this trailer with the Chevy. So I thought I would ask some actual owners to get their experience on larger trailers. Also if anyone is pulling a fifth wheel. Any knowledge would be appreciated.
  2. Sep 7, 2017 at 7:07 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Roughly how much does the trailer weigh?
  3. Sep 7, 2017 at 7:23 PM
    jsmithtx
    Jimmy
    2008 Tundra
    I have no idea. Just curious what other people are towing. I've seen some pretty big bumper pulls behind Tundras. Wanted some idea about what is a realistic range. I want to pull through the mountains of Colorado.
  4. Sep 7, 2017 at 7:30 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I pull a 4K lb boat around like it's not even there.
    Pulled a 25' toyhauler w my 97 Silverado. Only on flat terrain though. It was about 8k loaded.
    Before you start pulling through mountains I'd find out how much it weighs. In your owners manual it'll tell you what your truck is rated to tow.
  5. Sep 7, 2017 at 7:35 PM
    jsmithtx
    Jimmy
    2008 Tundra
    Yeah my Chevy would pull my trailer fine on flat ground and no wind. That's why I was wanting to hear from people that pull bigger trailers. I'll check the tow rating for sure. Thanks.
  6. Sep 7, 2017 at 7:37 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    AGia15, ColoradoTJ and NewImprovedRon like this.
  7. Sep 8, 2017 at 3:55 AM
    A lot of factors play into this equation. Where your physically located, where you plan on going and how much, what you are willing to do...and not do.
  8. Sep 8, 2017 at 4:49 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    We have a Chevy 5.3 2500 at work, pulls an equipment trailer with skidsteer or mini-ex regularly. I would estimate towing weight between 9k-13k regularly. It is a regular cab, 6.5 bed. Not the ideal towing machine but it gets it done just fine. My rough estimate on a 19' travel trailer empty is 5k, give or take 1k (manufacturer, options, accessories...) . The Chevy should have had no issues on any terrain.
    I'm looking at 20'-24' Toy Haulers right now. I plan to keep my loaded weight under 8k. I'm not worried about the Tundra pulling it.
  9. Sep 8, 2017 at 5:23 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    2500's do not come with the 5.3. They come with a 6.0 which is a much more powerful engine.
  10. Sep 8, 2017 at 5:32 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    We've got a 1500 and 2500 that look damn near identical, I assumed they were the same motor. They eat fuel the same. They both tow the same. I know for fact the 1500 is the 5.3. My bad, not a GM guy.
    mdavis[QUOTED] likes this.
  11. Sep 8, 2017 at 5:43 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Payload rating on the Tundra will be the limiting factor. Payload is the tongue weight of the trailer, plus occupants of Tundra, plus anything else you put in the Tundra. My 2014 Crew Cab 4wd has a listed payload of approx. 1300lbs. My 20 foot travel trailer (loaded weight of 4500 lbs) has a tongue weight of about 550 lbs. This means that me, my wife, 3 kids, and their bikes and crap that we put in the bed of the truck must be less than 750 lbs. While the Tundra can tow a 9000 lb trailer, it will run out of payload capacity. A 9000 lb trailer will have a tongue weight of at least 900 lbs. So if you tow something that big, then you run out of payload capacity first.
  12. Sep 9, 2017 at 7:20 AM
    Paulie T
    Paulie T New Member
    Paul
    2014 Silver Tundra SR5 4WD
    TRD sway bar Air Lift air bags Torklift camper tie downs
    I pull a 26' fifth wheel with a 5.7L Tundra. Trailer tongue weight is around 1100 lbs. and trailer dry weight around 6500 lbs. My payload is 1500 lbs.. I've towed this rig over many CO mountain passes with no issue however I would not tow a heavier fifth wheel than mine. The main focus is descending and learning proper gear selection and use of trailer brakes. Prior to the fiver I had a 1700 lb. truck camper. Use of air bags helps to keep rear closer to unloaded height and Load Range E tires provide much greater stability.
  13. Sep 9, 2017 at 8:09 AM
    You must have a Keystone Cougar 291.
  14. Sep 21, 2017 at 11:10 AM
    koebeljm
    koebeljm New Member
    2010 Tundra
    None
    I have a 23' Rockwood Travel Trailer that I pull with my '10 Tundra 5.7 liter. The trailer weighs about 6000lbs dry and probably around 7000lbs when we fully load up. When we started we had a lot of sway but put on a sway bar and that fixed it. Overall the Tundra does a pretty good job but traveling with something that big and heavy does put a load on the truck. Getting about 7mph when towing so range is pretty short between fill ups. Thinking about getting a dodge/ford diesel. At most campgrounds those 2 trucks are the most popular and people swear by them.
  15. Sep 21, 2017 at 11:43 AM
    Rhubarb Johnson
    Rhubarb Johnson New Member
    Rhubarb
    '17 TRD Pro Dbl Cab; Barc Red
    New windshield wipers....just getting started
    I'm with Koebeljm, and tow a 23' Rockwood. Mine is "Roo" and weighs about 5500lbs when loaded with bikes and things also in the bed. As has been stated there are a million variables including the hitch weight and your setup.
    We towed this same camper with a Buick Rainier, 5.3 V8, which is similar to the Chevy truck engine. It had the power, kinda. Could go through the mountains, but really didn't like it much. Had modified with a transmission cooler, truck tires, and heavier shocks. The worst was when a semi or larger vehicle passed....push/pull/push from the wash.
    With the Tundra there is a world of difference. It tows well and, although you still know the camper is back there, there isn't the semi push/pull when they pass. Only a slight movement. MPG ranges to about 10 or 11 on the flat with a gentle throttle touch. The tow/haul button is great for getting rolling, but doesn't do much for mpg.
    I would recommend as a TOTAL novice compared to many here...a WDH and sway control. My setup uses friction bars and with the proper adjustments (took about 2 hours...like I said I'm a novice) managed to get the front of the truck to remain nearly level and the rear to squat about an inch. The Pros are not really set for towing, but it works for camping 5 or so times a year.
    Best of luck
    QSX15 likes this.
  16. Nov 24, 2017 at 9:49 AM
    Retched1
    Retched1 New Member
    Aaron
    2017 Tundra Sr5 CrewMax
    2017 Tundra, with 5500lb 26 foot jayco. No issues over a local pass.
    AGia15 likes this.
  17. Jan 29, 2018 at 3:58 PM
    Cutlr7
    Cutlr7 New Member
    I tow a 24' enclosed car trailer and loaded with my Chevelle it's about 7k but is over 9' tall but with WDH and air bags(no needed yet but have them)....she gets it done.....
  18. Jan 29, 2018 at 6:06 PM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    A lot of us tow stuff in here. We tow a 34-foot Forest River Ultra-Light Rockwood camper with our Tundra. (We call them Rocky and Bullwinkle) Rocky is around 6,000 pounds but I'm sure it's closer to 8,000 when we have all loaded up for camping.
    The only mods I've done to my 2014 5.7L Tundra is replacing the stock mirrors with Toyota tow mirros and I put some Firestone airbags in the back which helps keep the truck level when the trailer is back there.
    And I second that requirement to also have the anti-sway hitch system in Colorado. My RV dealer won't even sell a camper unless the buyer has them.
  19. Jan 29, 2018 at 6:34 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I tow a 22' Champion Bay that scaled at 4650 and 1/2 tank of gas. 1/2 tank is about 45 gallons. When I weighed I did not have it loaded up with tackle. Loaded with tackle and full tank it would be 5000 lbs. I pass people easily on 2 lane roads. TT will have a little more wind resistance. Problem with 5th wheel will be weight on bed. Look up your current trailer and anything looking to buy on NADA. They list weights. Typical hitch weight on boats is around 10%. I get about 1" of drop on rear. Would like to have a AAL but accessing stuff in bed is hard enough now. Might add a sway bar but so far no real need.
  20. Jan 29, 2018 at 7:28 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    The 5.3 chevy is a great engine but absolutely sucks at towing they do not produce enough torque. Now the chevy 6.0 is very comparable to the Toyota 5.7 but the Toyota 5.7 combined with how Toyota has there transmissions and gearing the 5.7 will pull nicer then chevy all day every day.
  21. Jan 30, 2018 at 3:33 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I had some real good prices on Chevy's LTs with the 5.3. Would not touch the AFM engines with 10' pole. Plus a lot of people having problems with Chevy torque converters. Liked the features on Chevy. Especially the locker and color matching on front end and bumpers. Might have bought if I could have got bigger motor in LT.
  22. Jan 30, 2018 at 3:44 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Do you level with airbags first and then attach hitch bars or the other way around?
    Thinking about airbags.
  23. Jan 30, 2018 at 4:59 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    This is the system that I have on my 28' toyhauler, around 8,000lbs loaded.
    https://www.equalizerhitch.com/how-equalizer-works
    This takes care of load distribution and anti-sway in one package. Really easy to use and adjust.
    Instead of airbags, I went with SumoSprings. I wanted something I could install and forget. I also didn't want to worry about failures with an airbag system when out on a trip. Whether it be a line, compressor, or bag failure, I just didn't want to have that possibility.
    But really, with a properly setup LDH, airbags or SumoSprings shouldn't be doing a whole lot of the work. They're a good helping hand, they help during breaking, and with bumps that would load the rear suspension.
  24. Jan 30, 2018 at 5:07 AM
    Level with the LDH first, then use Airbags. Put the minimum amount of air in the bags for the desired result.
    Airbags work against the LDH if you really think about it, especially sway control.
  25. Jan 30, 2018 at 5:09 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Which rating SumoSprings did you use and why? I'm considering them, had Air Bags on my 2016 band they were a pain, always adding air.
    ColoradoTJ likes this.
  26. Jan 30, 2018 at 5:26 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
  27. Jan 30, 2018 at 9:05 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I pull a 3600lb car and the trailer weighs roughly 1850lbs. I cant even tell its back there, but 550hp helps out. My gas mileage is disgusting. But I didn't buy an econo car.
  28. Jan 30, 2018 at 5:44 PM
    ColoradoBoo
    Rick
    The air bags didn't replace the rear shocks so it stays level except when the trailer is attached. I keep them at 45 psi when not towing and around 90 when I'm towing. You can get the on-board air compressor and interior controller but they aren't cheap so I just had the installer mount the inflator valves on both sides of the rear license plate. (It's plastic so just a few small holes to secure them) I have a portable 12-volt air compressor that attaches to the truck that I use for both the camper tires and the Firestones. They really do make a big difference...doesn't sag a bit now.
  29. Mar 5, 2018 at 4:57 PM
    MRTUND460
    MRTUND460 New Member
    2010 CrewMax Platinum
    TRD Supercharged, Doug Thorley headers, MBRP cat back exhaust, DAP Tuned, 4.5" BDS lift, Firestone airbags, TRD sway bars, TRD big brakes, Icon CNC upper control arms Fox DSC shocks all 4 corners, Deaver custom rear leaf springs, 2018 Sequoia headlights.
    45 psi unloaded? Seems a bit high, I don't even have them that high when I'm towing my trailer. I'm at 5 psi when not towing, anything more and it starts lifting the rear end up.
  30. Mar 6, 2018 at 6:51 PM
    ColoradoBoo
    Rick
    You're right...I was thinking "4-5" but typed 45...just enough to keep them from being flat.
    MRTUND460[QUOTED] likes this.
