Towing in S6 or D?
Discussion in 'Towing & Hauling' started by Tsm503, Aug 18, 2022.
  1. Aug 18, 2022 at 2:34 PM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Why do some people tow in S6, is D with Tow/Haul mode the right way to go? I have a column shifter
  2. Aug 18, 2022 at 2:39 PM
    NWPirate
    Zach
    WA
    Welcome from WA!
    The manual says tow/haul on and in S4.
    I'll knock it up to S5 if it's flat ground or downhill.
    Keeping it out of D lowers your transmission temps.
  3. Aug 18, 2022 at 2:44 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Easier to lock out of overdrives if it starts hunting if it's already in D6. Just flick the thumb switch.
    On my truck anyway it will unlock the converter or downshift out of 6th at exactly the same engine load so it doesn't stay in top gear longer in S mode vs D. Whatever throttle it needs at 1800 rpm to reach 92% load on the scangauge is exactly when it shifts in either case.
    Edit: ah, a '21. Use S4 when pulling weight. Fluid cook, many hots
    NWPirate likes this.
  4. Aug 18, 2022 at 2:58 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    On top of what's been already said, if you shift from D to S, even at highway speeds, it will default to S4. At least in S6, you can drop one gear at a time.
    JDR76, endagon and NWPirate like this.
