Towing Hitches?
Discussion in 'Towing & Hauling' started by Ryan Mc., Jul 22, 2016.
  1. Jul 22, 2016 at 7:13 AM
    Ryan Mc.
    Ryan Mc. [OP] New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    2015 Tundra DC w/ tow pkg 5.7 (stock)
    I recently acquired a towing hitch. It is a 2" drop 2-5/16" ball with a towing capacity of 12,000 lbs and the hitch is rated up to 16,000 lbs. It is a regular set-up, no weight transfer.
    Mind you I do not have a trailer yet but when I do, I plan on towing to the max of my Tundra (10,300 lbs)...being a toy hauler around the 18' - 20' range. Nothing BIG, maybe a 2 toy max setup...like atvs, or maybe 3 including a dirt bike.
    Is the hitch I received junk/waste of money since it doesn't have a weight transfer system?
    Is 2-5/16" a good size or should have I acquired a 2" ball?
    Is a weight transfer system recommended or required when towing in the 8-10k lbs range?
  2. Jul 22, 2016 at 8:47 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i can only answer part of what you're asking as i only haul a 10' aluminum trailer for my quad.
    the drop hitch you bought sounds fine and a 2" drop is pretty common but realistically you don't know how much drop you need until you hook up your toy hauler and see how level it sits.
    also, you buy the ball according to the size of the hitch so until you decide what you're dealing with it don't go spending trying to guesstimate what you'll end up with.
    past that stabilizers are something i've never had to pleasure of dealing with so maybe someone else can chime in.
    my little tacoma used to have zero issues pulling my quad around
    f2063870-7164-48ff-8486-504f72a62a80_zps_481791a2cdafbdfcf492bb9e936372057a129e97.jpg
  3. Jul 22, 2016 at 9:19 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    A 2" drop hitch is not gonna cut it, regardless of ball size or stated rating. You are going to need a weight distributing hitch to tow at max capacity. This is assuming you have the factory tow package. A simple drop hitch is more suitable for making dump-runs with a utility trailer. My rule of thumb is, if the trailer you are towing, is big enough to need its own brakes, you should be using a WD hitch.
    ColoradoTJ likes this.
  4. Jul 22, 2016 at 10:39 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    What he said.
  5. Jul 22, 2016 at 10:43 AM
    Ryan Mc.
    Ryan
    Mission Viejo
    So then if this is true, why do they make drop hitches without WD? After acquiring the hitch and looking at my dad's set-up, it is a mystery why they make such a device when it is useless.
  6. Jul 22, 2016 at 10:52 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    A drop hitch just describes the shape of the shank. In fact, most weight distributing hitches use a drop shank of one type or another, depending on what it takes to level out your trailer. If your trailer is light enough, relative to your tow and load capacities, you can get away with just a simple drop shank as in the dump-run example. If your trailer starts pushing the limits of your capacity, then a WD hitch is called for. Now whether that WD hitch uses a drop shank or not, is an entirely different conversation.
    As to why they make non WD hitches; They are not useless but like anything else, they should be used in the appropriate situations. Your stated goal of towing an 8-10k toy hailer is not one of them
    Now when all is said and done, its your decision as to what type of hitch to use. There are no tow-police hereabouts, but hey, you did ask :)
  7. Jul 22, 2016 at 10:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    These hitches are fine for smaller trailers.
    edit: ^^what he said. He beat me to it.
  8. Jul 22, 2016 at 12:41 PM
    Ryan Mc.
    Ryan
    Mission Viejo
    Thanks. I do understand the drop hitch principle. I just don't understand why make a non WD hitch that can handle 16000 lbs? That part seems useless. I'd assume anything over 16k would be better with a WD.
  9. Jul 22, 2016 at 1:17 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    An LDH setup like this will serve you well in the long run. I've been using blue ox for the past few years hauling cars.
  10. Jul 22, 2016 at 2:54 PM
    Oh lord...not this again...LOL
    bandit[QUOTED] likes this.
  11. Jul 22, 2016 at 3:03 PM
    Good question Ryan. There are other trucks on the market that can tow this kind of weight without a LDH. A F-550 comes to mind, with maximum of 2500 lbs tongue weight and 20K trailer weight. The F-550 also can tow 30K with weight distribution. In the end, it is up to the user to purchase the correct equipment. I have a hitch in my truck now that is way over the rating of my truck. No harm in doing that.
    FYI, our Tundra's require a LDH after 5K lbs of trailer weight. I have towed more with no LDH, but I wasn't on the highway either.
    Ryan Mc.[QUOTED][OP] likes this.
  12. Jul 22, 2016 at 5:48 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Very good information here. Definitely need wd hitch with toy hauler. I would recommend equalizer brand from experience with different ones
  13. Jul 22, 2016 at 7:21 PM
    That is what I have.
    @bandit might suggest a blue ox LDC, and if I was in the market I would look at those as well.
    bandit likes this.
