TOWING CAPACITY
Discussion in 'Towing & Hauling' started by willyferg, May 18, 2021.
  1. May 18, 2021 at 1:37 PM
    willyferg
    willyferg [OP] New Member
    william
    2017 4.6l v8 tundra crewmax
    I Have 2017 4.6l V8 Tundra Crewmax looking to pull 29ft TT Dry weight 4850 do I have enough truck
  2. May 18, 2021 at 1:42 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Did you check the towing/hauling forum?
    Happy reading
    : Sorry,my bad! Your in the T/H section.lol
    Cpl_Punishment likes this.
  3. May 18, 2021 at 1:43 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Post your door sticker and the answer will come.
    Also dry weight does not mean much. Look at the gross weight for the trailer. You can probably guess 15% tongue weight on the gross number. That number comes out of your cargo capacity of the truck.
    Cpl_Punishment and mountainpete like this.
  4. May 18, 2021 at 1:45 PM
    Redcon41318
    Redcon41318 New Member
    I would say no, based on the length and weight. Just know a truck or tundra can pull anything but can you pull it safely as possible?
  5. May 18, 2021 at 2:18 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Weight sounds fairly reasonable but it's long. I'm actually surprised a trailer that big is that light.
    If you're towing when it's windy, that trailer may throw you around.
    twistedcricket and GODZILLA like this.
  6. May 18, 2021 at 2:41 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    If this is a box trailer and you will be in a windy area I would seriously consider a propride or Hensley hitch.
    twistedcricket likes this.
