Towing capacity?
Discussion in '2.5 Gen Tundras (2014-2021)' started by racervx54, May 16, 2015.
  1. May 16, 2015 at 7:45 AM
    racervx54
    racervx54 [OP] New Member
    2015 trd pro inferno
    Ok 2015 cm trd pro here. What's the difference between the 7200 lbs and the 10k towing capacity? I am assuming the only difference is the hitch. Class 3 vs Class 5? Anyone have any info?
    Reason I am asking I have a 28 ft enclosed at about 8000 to 8500 lbs.
  2. May 18, 2015 at 11:38 AM
    racervx54
    Nobody?
  3. May 18, 2015 at 11:45 AM
    Mike Tread lightly.
    south carolina
    8000 to 8500 pounds is a class 5 hitch.. can the tundra do it yes. I would make a piece of advice here. With that much weight make sure you have a bigger transmission cooler than factory.
    Sorry about that I dont know how I miss your post. Strange.
    Im going to assume the 7200 is for class 3 and 10k is for class 5 weights.
  4. May 18, 2015 at 1:10 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I thought Class 4 hitch is rated up to 10,000 lbs.
  5. May 18, 2015 at 2:02 PM
    Mike Tread lightly.
    south carolina
    You rather over rate the hitch then under rated it and stress it out.
    Edit.. I have not seen a class 4 hitch in years.
