Towing Capacity
Discussion in 'Towing & Hauling' started by Pregnant Tacoma, Mar 30, 2023.
  1. Mar 30, 2023 at 12:37 PM
    Pregnant Tacoma
    Pregnant Tacoma [OP] New Member
    Kennebunk, Maine
    2017 Tundra Limited CrewMax 4X4
    BakFlip MX4 Tonneau Cover TRD Dual Exhaust
    Can I haul a 5th wheel with my 2017 Toyota Tundra Crewmax 4x4 Limited?
  2. Mar 30, 2023 at 12:45 PM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    Probably not. The more important number is your payload capacity. Most Tundra's have 1200-1500 payload, the pin weight on most 5th wheels is at least that.
    Edit: On our last trip I saw 2 Tundra's pulling the smaller Grand Design Reflections. On paper the lightest pin is 1166, which is most certainly a few hundred lighter of real world. So can a Tundra pull a 5th wheel, yes. Should a Tundra pull a 5th wheel, it depends.
  3. Mar 30, 2023 at 1:14 PM
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    I've seen videos of folks towing 5th wheels with a Tundra but never seen one in person. Even in videos it looks really sketchy. A half ton pickup should be nowhere near a 5th wheel, they just aren't designed to haul them. Except maybe the Escape 5.0 or the Scamp 19' but that's only because they're probably the most lightweight and smallest 5th wheels ever made.
    RCwyoming and Cpl_Punishment like this.
  4. Mar 30, 2023 at 1:20 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The big 3 won't even sell you a fifth wheel hitch for their halftons and they can all be optioned with more payload than a Tundra.
    Mattedfred and Lake.Life24 like this.
  5. Mar 30, 2023 at 2:03 PM
    UnlimitedRevs
    UnlimitedRevs New Member
    The PNW
    '17 SR5 Double Cab Black
    BBS TRD Professional Wheels
    Can it? Probably, but the Tundra also "towed" the space shuttle a few hundred feet. Safely? Definitely not. As others have mentioned the pin weight alone on 99% of all 5th wheels will exceed the Tundra's payload capacity, which also must include the weight of passengers and cargo in the truck.
    Also note that the pin and hitch weights listed for trailers are generally dry weights, and do not include the weight of trailer batteries, onboard generators, filled propane and water tanks, and trailer cargo and other add-ons, like solar panels and washer/dryers, etc.
    Half-ton trucks, especially Tundras, are not designed for carrying that kind of weight, no matter how much they can theoretically pull.
    Cpl_Punishment likes this.
  6. Mar 30, 2023 at 2:05 PM
    My limited Tundra 4x4 crewmax has a payload of 1130 on the door sticker. Good luck finding a 5th wheel with a measured pin weight under that.
    Mattedfred and Cpl_Punishment like this.
  7. Apr 6, 2023 at 1:03 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    You could probably pull something like the Escape 5.0 or the Scamp 5th wheel... <700lb pin weight.
    Mattedfred likes this.
  8. Apr 7, 2023 at 4:00 PM
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    My son pulled a fifth wheel that was in the weight limit. The biggest problem was that with the crewman cab, it put the front of the trailer into the cab when he tried to turn. So, he up-graded his truck to a 3/4 ton.
