Towing capacity with upgrades?
Discussion in 'Towing & Hauling' started by Focus2017, May 29, 2017.
  1. May 29, 2017 at 8:08 PM
    Focus2017
    Focus2017 [OP] New Member
    David
    2014 TRD 5.7V8 Limited
    Cold air intake Blacked out Aftermarket Exhaust Fuel Rims Leveling Kit Magnum Front Bumper with light bar
    I have a 2014 Tundra 5.7 v8 limited and recently added a cold air intake and brand new single exhaust giving me about 100HP and 65 Ft per LBS of Torque. I have a 8500 lb trailer fully loaded and want to go to a 1050lb trailer and want to know if I will be ok cause I refuse to change trucks or drive anything other than a Tundra. Where is the tundra turbo diesel :) Thanks for your help
  2. May 29, 2017 at 8:23 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Bwahahahaaaaa. Might wanna check your numbers man
    15whtrd, MakMurph, Law323 and 6 others like this.
  3. May 29, 2017 at 8:24 PM
    Bear
    Bear
    Custer, SD
    I mean, unless that single exhaust is an STS turbo...
  4. May 30, 2017 at 8:09 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    The towing capacity also takes into account frame stress, you could end up bending the frame..Nissan was skewing their towing numbers on the Titan and people were ending with bent frames and shattered axels.
  5. May 30, 2017 at 8:13 AM
  6. May 30, 2017 at 8:29 AM
    Bear
    Bear
    Custer, SD
    I want these mods...
  7. May 30, 2017 at 8:42 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Setting aside that those mods most certainly do not add 100 HP. Tow capacity is generally most related to the weakest link. In stock form, the 5.7 is not even close to being the weakest link. The frame, brakes, differential, transmission and axles all play an important role.
    Were it simply a matter of engine power, the super-charged Tundras would have a much higher tow rating.
    15whtrd, gosolo and kenomouth64 like this.
  8. May 30, 2017 at 8:53 AM
    blizz86
    blizz86 New Member
    I have the troll mod on my tundra too. It lets me see the sunset from the moon if i go full throttle.. but only if i warm the engine up for exactly 23.2 seconds.
    T-Rex266, kenomouth64 and Bear like this.
  9. May 30, 2017 at 9:38 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    If that stuff adds 100 HP, I would be highly surprised! More like 10-25HP, maybe... However the motor is not the problem, the suspension is going to be the first problem. Then brakes, then frame, then transmission, then differential, then wheels/tires.
    ColoradoTJ likes this.
  10. May 30, 2017 at 10:50 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Naw. You need the throttle body spacer for that.
    15whtrd likes this.
  11. May 30, 2017 at 11:05 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Focus2017
    I'm curious why you think those 2 mods are going to net you 100hp & 65ft/lb of tourqe
  12. May 30, 2017 at 11:52 AM
    PMG
    PMG New Member
    Welcome to the forum
    SouthBoundSteve likes this.
  13. May 30, 2017 at 11:52 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    1. Troll or you bought into some lies
    2. Super charger adds 100 - 150 HP. That costs about $8k installed. Why would anyone want a SC if they can add almost that with about $1k worth of intake and exhaust.
    3. Cant change the tow capacity with performance upgrades.
  14. May 30, 2017 at 7:30 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hello David and glad to see you towing with your Tundra. Not going to get into your gains from your engine mods, but you also want to double check your trailer posting numbers. If I am reading correctly, are you looking at moving to a 10,500 lb trailer ? If that's the case, I would advice to keeping your 8500 lb trailer. That one in itself is pushing the limits. My travel trailer I tow is close to 8000 when fully loaded with the extra water tanks I added. My suggestion to you, if not already done, would be to add air bags and re-gear. The 5.7 in stock form works well, but the weak link as others have stated are brakes, etc. I would not advice you pushing beyond the limits in towing a 10,500 lb trailer if that's what your numbers were meant to be in the original post. Good luck with all.........
    gosolo likes this.
  15. May 30, 2017 at 10:54 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Looks to me like a "0" jumped from your trailer weight to your increased Hp figure.
    babbitt, CM-LENNY and Bear like this.
  16. May 30, 2017 at 11:19 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    He is a new member go easy on 'em with HP numbers guys. David, its more like 10hp after CAI and muffler upgrade and even that 10hp gain goes unnoticeable in daily driving. The only person who can add 100hp with CAI & Muffler is Dom from Fast & Furious and he is not into Trucks.
    Bear and Spvrtan like this.
  17. May 31, 2017 at 4:13 AM
    Bear
    Bear
    Custer, SD
    The difference a zero makes...but I don't think it was unintentional o_O
