towing boat/ RCTA issues
Discussion in 'Towing & Hauling' started by tommyboyrn, Mar 30, 2023.
  1. Mar 30, 2023 at 4:47 PM
    tommyboyrn
    tommyboyrn [OP] New Member
    Tom
    2021 Tundra 1794
    So I have a recently purchased 2021 Tundra 1794. I haul a boat and trailer occasionally. while backing that boat trailer the RCTA ( I assume its that one) constantly beeping at me. I have my trailer connected to the 7 pin round plug and everything works like it should.
    I never received an alert that there was a trailer connected or anything and towed in tow/haul mode. How do I go about adding the trailer to the truck, if possible? or how to disable the RCTA?
    Ive looked through the manual but wasnt much help.
    Tom
  2. Mar 30, 2023 at 4:58 PM
    Your boat probably has surge brakes. The truck is not seeing any electric brakes to control, so it’s not adding the trailer to the trailer brake control system. Push the P button above the brake controller on the left to disable the park sensor function.
  3. Mar 30, 2023 at 5:13 PM
    tommyboyrn
    Tom
    2021 Tundra 1794
    my boat (18 ft) doesnt have brakes at all on trailer...i think I have that sensor disabled already but will double check. thank you for the info.
    tom
  4. Mar 30, 2023 at 5:14 PM
    crazy it uses a 7pin plug
  5. Mar 31, 2023 at 4:02 PM
    tommyboyrn
    Tom
    2021 Tundra 1794
    So looking at my connections, the boat has a flat 4 pin that i connected to the 7 pin round plug via adapter....would this be a reason for truck not to recognize trailer attached or is it not recognizing because of no trailer brakes?
