towing at maximum CGVW
Discussion in 'Towing & Hauling' started by Johnet46, Jun 26, 2019.
  1. Jun 26, 2019 at 10:02 AM
    Johnet46
    Johnet46 [OP] New Member
    2014 toyota tundra
    I'm kinda new to Tundras.com...I have a 2014 Tundra Limited and have a Forest River Shockwave Toy Haul with GVW of 10,500 and very worried about how the Tundra will handle pulling because I know I am maxed out on the gross combined weight which is I think 16,000 lbs. So here is what I have learned:
    When I bought the trailer, I haul a HD TriGlide...1,200 lbs, my first few trips,around Yuma AZ...and to Benson AZ...I knew the Tundra was towing at MAX, could not use cruise control, max speed was about 60 mph, climbing to 4,500 ft at about 40-45 mph at 2500 rpm's and got 7.2 mpg. I was very concerned for several reasons:
    I leave Yuma for the NW and travel up the Rockies for a month to WA...climbing through passes from 5-7 thousand feet - then return to Yuma in October.
    SO, I did not want to trade in for a three quarter ton rig and researched what I could add on the Tundra that would make the towing safer and here is what I added:
    Firestone Air Bags
    TDR Rear Sway Bar
    AND after much deliberation bit the bullet and installed TDR Cold Intake and TDR Cat Back Dual Exhaust.
    Results:
    I could pull grades of 5-7 percent at 35-45 mph at 2500-2700 RPM's
    Still could not use Cruise Control - not a problem
    On descending down mountains I had to start at 35 mph and use the trailer brakes and take my time...not a problem
    MPG increased from 7+ to 10+ MPG and that is significant as the Tundra only has a 26 fuel capacity so I stop every couple of hours...need a stretch anyway.
    But the big news is my MPG increased from 12-13 mpg to 17-18 mpg when not towing.
    Hope you all find this useful info.
  2. Jun 26, 2019 at 10:36 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You need a weight distribution hitch...
  3. Jun 26, 2019 at 10:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    If you are getting 10+mpg towing that size of trailer......something with my tundra ain't right. 4k loaded to the brim and I think I get around 9mpg on a flat road
  4. Jun 26, 2019 at 1:19 PM
    What model shockwave do you have?
    I’m betting you’re over on a few things already.
  5. Jun 29, 2019 at 7:26 AM
    Johnet46
    2014 toyota tundra
    shock wave 27 RQDX
  6. Jun 29, 2019 at 8:08 AM
    So here are the specs on your toyhauler:
    The 2014 Tundra has a tow rating (assuming you have a 4wd) of 9600 lbs unless the sticker on the inside of the drivers door jam says otherwise. Over on trailer GVWR.
    The maximum tongue weight rating on this year Tundra is 980 lbs. Over on that already by 100 lbs. This weight can vary depending on if empty or loaded up. 1092lbs is what this trailer is rated for empty.
    The load capacity for your Tundra is 1410 unless you have the DC model. Then it's 1500 lbs, unless there's a little yellow sticker inside the drivers door jam stating a reduced weight rating due to options (most likely there is). So if we totally ignore the tongue weight rating, and add you and the misses personal weight 350 lbs. (lets go with 350 lbs, adjust if lower or higher). any additional cab/bed weight, add that up.
    1410-350=1060 lbs So this means without anything loaded up, you are assumed to be 32 lbs overweight. I'll just leave off the weight of the LDH of 75 lbs. You are already over.
    Gross vehicle weight rating of truck is 7200lbs. Truck weighs 5850 lbs. With the trailer and assumed occupants weight, the Truck is at max capacity, if the capacity is 1410 lbs.
    Gross combined is 7200+10995=18195 lbs. You would be over by 2195 lbs on GCVWR.
    Your assumptions were correct. Pretty much maxed out on one area and over on all others.
    Actual weights might lower some of this, except the tongue weight is just to much.
    Hope this helps.
    plumber802, JH5370, Ely010606 and 3 others like this.
  7. Jun 30, 2019 at 7:55 AM
    Johnet46
    2014 toyota tundra
    Colorado TJ,
    Thank you for the Spec's....so here is how I keep the CGVR to or close to 16000 lbs:
    My HD weighs 1200 Lbs and when loaded reduces the tongue weight to 750 lbs and have no problem being over weight.
    When traveling with the HD loaded I only travel with enough water to get me from A to B using 10-20 gallons of water till I get to shore water.
    I have a 35 gallon fuel tank but only fill 5-10 gallons for generator use...I never use that fuel for my HD.
    AND most if my extended trips are by myself as they are HD riding trips...therefore minimum clothing and stuff.
    When traveling on interstates regardless of the posted speed limit I travel at 55-60 mph in the slow lane I am never in a hurry,
    On non interstate roads usually to my final destinations I travel at 50-55 mph and use turn outs for slow vehicles.
    On my return from Yuma AZ to the NW, the Olympic Peninsula in WA...I traveled 1500 + miles in elevations from 4000 to 7500 feet for four weeks and did not get under 500 feet till I got to I-5 in Oregon.
    When I got to Port Ludlow, home for the summer...I padded the Tundra Hood and said, "That-a-Boy."
    JT
    JohnLakeman likes this.
  8. Jun 30, 2019 at 9:07 AM
    That is a little more comforting that your tongue weight is a lot lower than advertised due to loading up the Harley Davidson. You scale that yourself or use a tongue weight scale?
    Still close on tongue weight, and GCWR, but the way you tow should make it safe for you. The Tundra is a workhorse, from what you have seen.
  9. Jun 30, 2019 at 9:17 AM
    Johnet46
    2014 toyota tundra
    I went to the dealer, Little Dealer Little Prices, in Phoenix AZ...with my HD and a tongue scale and weighed the trailer tongue empty, 1125 lbs...then loaded my HD..tongue weight 750 lbs...then bought the trailer.
    By the way what part of Colorado....one of my favorite states to travel and ride.
    JT
    JohnLakeman and ColoradoTJ like this.
  10. Jun 30, 2019 at 9:19 AM
    That was a good call. Check first, then buy.
    I'm in Colorado Springs.
  11. Jun 30, 2019 at 12:42 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    TJ, doesn't the j2807 spec account for two 150# passengers, full fuel tank, 70lbs WDH, and for conventional trailer towing that 10 percent of the trailer weight is on the tongue -- the payload number is then derived after accounting for those factors? Or am I misinterpreting something.
  12. Jun 30, 2019 at 1:10 PM
    Post #5
    https://www.tundras.com/threads/tow-ratings-guide-the-how-to.39211/
  13. Jun 30, 2019 at 6:55 PM
    TacoWuzzaTurd
    Scottsdale AZ
  14. Jun 30, 2019 at 7:10 PM
    Ah crap, you’re right. I forget that every time about the passengers and hitch. Good catch.
    From the SAR J2807 standards:
    In a nutshell, SAE J2807 requires the vehicle manufacturer to use a vehicle equipped with the popular options found on at least 33 percent of the vehicles sold for that model; they also must run the test procedures with the equivalent of a 150-pound driver and passenger. The truck is hitched in a specific manner to a trailer that meets SAE specs and puts the tow vehicle (the pickup truck) at its maximum gross combined weight rating, meaning the combined weight of the pickup, its maximum payload, full fuel tank and the weight of the trailer.
    Then a series of tests are conducted that target handling, trailer sway, braking, acceleration and component durability. The tests also include driving up the Davis Dam, a 7 percent grade that runs eastward out of Laughlin, Nev., for 11 miles to the top of the 3,500-foot summit in daytime temperatures of 100 degrees with the air conditioning going full blast. The vehicle manufacturer looks at all the data and decides what towing limits to place on that particular make/model vehicle.
  15. Jun 30, 2019 at 7:26 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Right so if you pack 2 big ol fat ladies in the truck, you're probably going to eat into your available payload number. On my 2018 SR5 Crewmax 4x4 TRD after yellow sticker on door I'm at about 1220 available payload. Since I weigh about 175 I have a little budget left per the j2807...oh but wait. There's the 70lbs of subs/amp, 50lb running boards I added, etc. etc... all counts against that 1220 payload. :D
    ColoradoTJ likes this.
  16. Jun 30, 2019 at 7:59 PM
    Exactly
  17. Jun 30, 2019 at 8:07 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    This is 'Merica', they need to up the weight to 300 for each occupant.:hungry:
  18. Jul 1, 2019 at 9:05 AM
    Jesusquintana
    Jesusquintana New Member
    Roger
    Central Texas
    2018 Crewmax 4x4
    So you don't eat into the 1220 until you exceed 370 lbs of passengers, hitch, etc. correct? Seems to me the true way to check payload is to get your curb weight on a cat scale and subtract that from 7200. Regardless of what j2807 says, you cannot exceed 7200 lbs and once you do you are overloaded right? The only way to increase the payload is to decrease weight of the tow vehicle. Dump the running boards, leave the tailgate at home, put the spare in the travel trailer, etc. if you want to get drastic.
  19. Jul 1, 2019 at 11:39 AM
    That’s essentially what is going on.
    TacoWuzzaTurd likes this.
  20. Jul 1, 2019 at 2:13 PM
    Jesusquintana
    Roger
    Central Texas
    2018 Crewmax 4x4
    Ok, I think the confusion comes with j2807 and payload numbers. I believe j2807 is used to calculate max trailer weight ratings but not the max payload rating of the tow vehicle. My truck at the cat is 6210 with me (225 lbs) in it and the number after add ons (yellow sticker) on my door jamb is 1200 so my guess is that Toyota weighs the truck after any add ons (i have a tss with spray in bed liner, 20 in wheels/ko2s, nerf bars, under carriage plate) and subtracts that from 7200 to get each trucks max payload. If I figured in the 370lbs buffer from j2807 the numbers would be off and I would be well over 7200 GVWR.
  21. Jul 1, 2019 at 2:29 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Yeah shit I just weighed mine too and I'm at 6340 with me in the truck. That's some paltry payload capacity.
    Atomic City Tundra likes this.
  22. Jul 1, 2019 at 3:21 PM
    Welcome to half ton trucks. :rofl:
    We just need to add up the factory weight and payload capacity, and you have the maximum GVWR.
    =7200 lbs. =7100 lbs.
    So if 370 lbs is already added into this rating, that’s not horrible.
    Let’s say you have 600 lbs tongue weight from a trailer and you have a couple extra passengers. We can just use 300 lbs for two extra.
    1570-900=670 lbs left. Not horrible.
  23. Jul 1, 2019 at 3:22 PM
    Now if an owner starts adding sliders, skid plates, bumpers, RTT, big tires and wheels, these numbers go down quick.
    JohnLakeman and TacoWuzzaTurd like this.
  24. Jul 1, 2019 at 6:19 PM
    Jesusquintana
    Roger
    Central Texas
    2018 Crewmax 4x4
    I’m trying to figure out what sr5 5.7 crewmax 4x4 has a curb weight of 5640???
  25. Jul 1, 2019 at 6:29 PM
    Stripped down, no floor mats, and only using Toyota scales. Lol
