Towing a 30 feet travel trailer
Discussion in 'Towing & Hauling' started by Tico-Tampa, Feb 6, 2019.
  1. Feb 6, 2019 at 7:41 PM
    Tico-Tampa
    Tico-Tampa [OP] New Member
    L.T.
    inhave a 2016 Tundra 4X4 TRD, I’m towing a 30 feet trailer, I use a equalizer system and airlift airbags, it feels heavie but it doesn’t sway when big rigs pass by me, am I way too overloaded ? The trailer sticker shows GVWR 8750, not sure how to calculate this numbers ...
  2. Feb 6, 2019 at 7:43 PM
    Tico-Tampa
    L.T.
    Here is a picture when I purchased
    alalmcgrath likes this.
  3. Feb 6, 2019 at 7:43 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You should be ok BUT I am no towin expert. @ColoradoTJ could shed some light on the matter
  4. Feb 6, 2019 at 7:45 PM
    Tico-Tampa
    L.T.
    I’m in Florida so we don’t have hardly any serious climbs or descents , I’m a little concerned on the breaking power
  5. Feb 6, 2019 at 7:46 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You’ve got trailer brakes, right?
  6. Feb 6, 2019 at 7:48 PM
    Tico-Tampa
    L.T.
    Yes sure! And I adjusted them, and they work ok considering the weight I’m towing
  7. Feb 6, 2019 at 7:50 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I guess just try not to follow to close to the vehicle in front of you, as you already know. If you’ve got trailer brakes then I wouldn’t worry too much about it. The TUndra will be fine
  8. Feb 6, 2019 at 7:52 PM
  9. Feb 6, 2019 at 8:00 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I'm towing closer to the limit of our tundras daily. We will be adding the sumosprings soon but we have had zero issues.
  10. Feb 9, 2019 at 10:52 PM
    Tex Man
    Tex Man New Member
    Wydaho
    2016 Tundra SR5 4x4
    @Tico-Tampa - I have towed a 30' travel trailer with my Tundra. The person we rented the trailer from had it full of potable water and double propane tanks. It was a LOAD! My Tundra handled it, however I was glad it was a rental and happy that I could take it back. 30' and 9,000 lbs felt like too much trailer for regular outings. My Tundra averaged 7 MPG towing that beast around for the weekend. Albeit, I was driving many hills and interstate speeds.
  11. Feb 10, 2019 at 3:40 AM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    What is the trailers dry weight?
    What is the hitch weight?
    Your probably not over weight by the numbers but to be safe your pushing the limits of your truck.
    Florida is relatively flat yes but other drivers and truckers go way over the speed limit lol
    Sorry I grew up there the hills scare me less
