Towing a 2 horse sland trailer
Discussion in 'Towing & Hauling' started by pjstruck, Jan 29, 2018.
  1. Jan 29, 2018 at 2:53 PM
    pjstruck
    pjstruck [OP] New Member
    2016 Tundra 2017 tundra
    Hey , who has experience towing a horse trailer ( 2 hrs. slant only plz.) Does your tundra stop your trailer well! Thanks for any responses!
  2. Jan 29, 2018 at 3:04 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
    Show some pictures of your tundra.
    I’m sure some experts om towing will jump in here soon.
  3. Jan 29, 2018 at 3:33 PM
    segelflieger
    segelflieger New Member
    Az
    16 TRD DC
    Icons
    Well Depends,,,, Recently had the flash done to my IBC(2016 dc towing pkg) and it was a noticeable improvement over the old software. Towed a two stall horse trailer bout 1k recently, 500 out empty and 500 back with probably only around 1k lbs worth of sheep, it did ok... Would I tow a large or heavy trailer with the IBC, no... I made a mount for my P2 when I need real brakes,,, Unplug factory harness, plug in adaptor harness,,,, set gain on P2(Tekonsha) and not worry. If you will tow a lot, my vote Tekonsha P2 or P3...
  4. Jan 29, 2018 at 7:39 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Not sure what you are asking. Weight is weight whether it be bricks or horses, and whether those bricks are laid straight or slanted don't matter much either. That said, yes, I've pulled straight loads, slant loads and crap loads. Tundra stopped them all just fine. Of course horse trailers have their own brakes, so they do much of the work.
  5. Jan 30, 2018 at 5:13 AM
    segelflieger
    Az
    16 TRD DC
    Icons
    I think what she means is the config of the trailer.... the horses stand diagonally across the trailer.
  6. Jan 30, 2018 at 9:56 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Yeah I got that. Just wasn't sure how it was relevant to tow or braking capacity.
  7. Jan 30, 2018 at 10:24 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Yep. Plenty of times with this old Miley 2 horse straight. Pulls and stops easy. She’s pretty light though and we just had 2 quarter horse mares inside.
    Hbjeff and ColoradoTJ like this.
  8. Feb 1, 2018 at 5:37 PM
    too tall
    too tall New Member
    I tow 6K trailer and can't imagine you'd have any issue. That said the factory brake controller update is NOT effective, possibly a little effective but nothing I could notice. I installed a Tekonsha P3. The difference is night and day. If you have the ability to get the Tekonsha, do it.
    ColoradoTJ likes this.
  9. May 3, 2018 at 6:18 PM
    CPCATTLECO
    CPCATTLECO New Member
    Charles
    2010 Dbl Cab 4.6, 2018 Dbl Cab TRD 5.7
    I'm new to the forum and have a 2010 SR5 Dbl Cab with 4.6 and towing package that was offered with that engine at the time. Does not have the factory supplied trailer brake, but I added a Tekonsha. I tow an S&H 3-horse slant load, mostly with 2 horses, but have carried 3 on several occasions. NO ISSUES on stopping, and we lived in Tennessee hills several years.
    We just purchased a 2018 Dbl Cab with 5.7 engine. What a difference in towing power! Factory controller took a bit to tune in, but seems to work fine.
    I'll post pics of the truck and trailer soon.
  10. May 3, 2018 at 6:56 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    My biggest load I pull is 6500lbs, no issues. I had the brake controller TSB done as before it did nothing, it brakes the trailer more now. I don't know if it can be better or not as I have nothing to compare it to.
  11. Apr 23, 2021 at 10:06 AM
    Joybell
    Joybell New Member
    For 6 years I towed a Mortiz steel stock/combo slant load 13 ft trailer with my 2015 4x4 double cab V8. I used a distribution hitch. Mostly I had just one horse and camping equipment. I also have an ARE high cap over the truck bed. The trailer weighs 3200 lbs empty and the tongue weight is 725 lbs. I just bought a new Jamco slant load 14 ft, solid aluminum (not just a frame and skin over it but tongue and groove aluminum planks) that weighs 3600 lbs empty with a tongue weight of 700 lbs. I expect it to do the same jobs. Hauling my horse all over the hills of Vermont, including a lot of wash board dirt roads. I weighed my unit, individually and hitched, on a feed mill scale and I am within the payload and GCWR.
