Towing 7000# Setup Advice
Discussion in 'Towing & Hauling' started by Mike19, Jun 21, 2019.
  1. Jun 21, 2019 at 10:33 AM
    Mike19
    Mike19 [OP] New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Hi everyone,
    I tow a 7000# TT or an enclosed trailer at times. I have around a 1-2” sag when the trailer is full capacity. I’ve scoured the forums and have read people put the following on their tundras.
    - Bilstein 6112 fronts
    - Bilstein 5100 rear
    - Coachbuilder Shackles +3”
    - Ride-Rite Airbags with F3 Air Commander
    I have a 19 TRD Sport CM and plan to put the Ride-Rite Airbags with F3 Air Commander. I plan to stay with my 20” wheels and the factory rake of 1-1.5”. I really don't want to lift if i can help it.
    Should I even upgrade my shorks and struts? What settings on the Bilsteins should I have to keep the factory rake?
    Do I need the shackle upgrade?
    TIA
  2. Jun 21, 2019 at 12:20 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Are you using a weight distribution hitch? When I hook up my 7K loaded trailer I sit with a very small rake, make .5".
  3. Jun 21, 2019 at 12:26 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    If you're not lifting it, your stock shocks should be fine. Spend your money on a weight distributing hitch and some air bags & save the new shocks for when yours are worn out.
  4. Jun 21, 2019 at 12:48 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    You could do the add a leaf route too if you don't want the complication of airbags.
  5. Jun 21, 2019 at 1:16 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Lifts don’t help towing so get those shocks out of the equation. Add a leafs will help but stiffen up the ride compared to air bags. If I were you I’d do airbags and good set of brakes. Rear TRD or Magnuson anti-away bar is a must. Want to spend more, do a big break kit, available from a few manufacturers starting at $1000+ and some decent towing mirrors...
  6. Jun 21, 2019 at 1:45 PM
    Mike19
    Chi town
    No WDH. So did you add a leaf, airbags or just stock?
  7. Jun 21, 2019 at 1:50 PM
    Mike19
    Chi town
    The TRD Sport has the front and rear sway bars already. So just stick with the airbags and upgrade to the TRD Big Brake?
  8. Jun 21, 2019 at 1:54 PM
    Azblue
    The Dirty T ( ^_^)_且
    WDH is mandatory, especially anything over 5000 lbs. If you don't use a hitch and start throwing money at leafs, bags, etc. Then you are wasting your money and not as safe as you could be.
  9. Jun 21, 2019 at 1:56 PM
    Mike19
    Chi town
    Got it. Anything over 5k used WDH. So under 5, add leaf or bags then. Thanks.
  10. Jun 21, 2019 at 2:15 PM
    Jrharvey02
    Nice, I’m running trd sports too and love em. As mentioned a WDH will help too. Big brake kit isn’t a necessity, but if you’ve got the cash, you’ll certainly appreciate ...others make big brake kits too, brembo, ebc, baer, ceika to name a few
  11. Jun 21, 2019 at 3:11 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    That was with a WDH and stock suspension
  12. Jun 21, 2019 at 3:17 PM
    Jrharvey02
    You’ll need 20” rims for most big brake kits to fit...
