Towing: 6 MPG @ 70 MPH
Discussion in 'Towing & Hauling' started by GregoryDavid, Oct 29, 2019.
  1. Oct 29, 2019 at 6:14 PM
    GregoryDavid
    GregoryDavid [OP] New Member
    2011 5.7 crew max
    I'm towing a 7500 lbs travel trailer. Gas mileage is ridiculously low (6mpg). Normal highway I am getting 11.5 mpg (not towing). Any thoughts or recommendations to increase this would be appreciated
  2. Oct 29, 2019 at 6:22 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    I'm guessing you're pulling a shoe box? if so, 60-65 is the sweet spot. have a lift? bad. Mud tires? Bad.
  3. Oct 29, 2019 at 6:23 PM
    ZPMAN
    Minnesota
    Check tire pressures, alignment, air filter and condition of spark plugs.
  4. Oct 29, 2019 at 6:27 PM
    timsp8
    NY
    Slow down. Tow in s4 or s5.
  5. Oct 29, 2019 at 6:37 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds about normal, maybe a little on the low side but if there's lots of hills and stuff sounds right
  6. Oct 29, 2019 at 7:47 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I tow that same weight through the hill country and average 8 or 9 mpg with 70 mph max.
    You’re towing something with the aerodynamics of a brick. I don’t think you will do much better but, try slowing down to 65 and keep the transmission in S5, downshift early to S4 or even S3 for hills.
    Also, we need more info about your truck. Is it stock? Have you done a tuneup recently? Where are located and what’s your average route look like?
    EDIT: Also your story is why toyota added the 38G tank in 2014. :rofl:
  7. Oct 29, 2019 at 7:57 PM
    This ^^^^
  8. Oct 29, 2019 at 8:01 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Sounds about right. I barely make it to the river on a tank towing my boat. 286 miles and 38 gal tank.
    Bigboitundra likes this.
  9. Oct 29, 2019 at 8:02 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    They added the 38gal tank in 2016.
  10. Oct 29, 2019 at 8:54 PM
    GregoryDavid
    2011 5.7 crew max
    I have a 2011 5.7L crew max with a tow package. It has a 3/1 level and AT tires. Needs a tune up for sure. 234,000 miles on it. No after market except for a K&N air filter (so no after market really). Pulling a 30 foot travel trailer. In Texas, drove from San Marcos (650 ft above sea level) to the gulf coast (about 150 miles). Mostly flat terrain. Trailer weight about 7500 pounds. (Crewmax cab, 20 gallon tank (BULLSHIT))
  11. Oct 29, 2019 at 9:01 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Last time I went to the coast from Austin I remember it being very hilly.
    You have a 26.4 gallon tank.
    I’ll echo my previous post.. slow down.
    Your 3/1 lift doesn’t help.
    Your post is not surprising but I think you’ll find a couple MPG by following the recommendations already posted by everyone.
  12. Oct 29, 2019 at 9:04 PM
    Sunnier
    Sunny
    San Diego, CA
    Try to tow downhill. :notsure:
  13. Oct 29, 2019 at 9:26 PM
    Ericsopa
    Ericsopa Old man and the sea
    You've got a few hills down I-37. Speed and headwinds off the gulf are your killer with that TT. I get 9-10 with a 4500# boat going the same route at 60-65 in 5th. You wont do any better unless you slow it down.
  14. Oct 29, 2019 at 9:37 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    11.5 normal highway?
    Hmm something seems off unless u are going 90...
    My Sequoia, which gets worse mileage than the Tundra, averages 16.5mpg combined (probably 60/40 highway/city)
    unclebeejo808 likes this.
  15. Oct 29, 2019 at 9:48 PM
    Being leveled and most likely bigger tires will really kill the fuel economy on these trucks.
    Do you have the Flex Fuel system? Lots of those caused some reduced fuel economy even if never using E-85.
    It is what it is when towing with a gas powered truck. Personally, there’s a lot more pros than cons to owning a gasser vs a diesel.
    TundraDude18 likes this.
  16. Oct 29, 2019 at 10:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What tires are you running
  17. Oct 29, 2019 at 10:12 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    You should first address why you’re only getting 11 mpg normally.
    Melikeymy beer likes this.
  18. Oct 29, 2019 at 10:19 PM
    Leveled and bigger tires, pretty normal mpg range. 11-13 is common.
    Hbjeff and Broncobroke like this.
  19. Oct 29, 2019 at 10:26 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I agree with this but I also think a lot of people aren’t calculating the percentage difference in to their mpg factors.
    You can look at your heads up and see 11mpg all day but if you’ve got tires that are 2” taller than stock and no speedo calibration, you’re actually getting 12 or 12.5.
    Hand calculating mileage between fill ups is the only way to get these figures accurate.
  20. Oct 29, 2019 at 10:31 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Probably the weight, speed and needing a tune up.
    However... I would also go get a stock paper filter for the air box. Any changes you make to that thing will cause you to lose low end torque. k&n, afe, anything to try increasing air flow... Bye bye low end.
  21. Oct 29, 2019 at 10:37 PM
    unclebeejo808
    Oahu
    I’m leveled with bigger m/t’s and average 16 o_O
  22. Oct 29, 2019 at 10:41 PM
    TruckyTruck
    Gary
    It's all that Hawaiian air :kona:
  23. Oct 29, 2019 at 10:46 PM
    Good point Steve.
  24. Oct 29, 2019 at 11:16 PM
    unclebeejo808
    Oahu
    Lol. Maybe
    TruckyTruck[QUOTED] likes this.
  25. Oct 30, 2019 at 4:27 PM
    GregoryDavid
    2011 5.7 crew max
    I have general grabber AT/x. 275/60/18 if I remember correctly.
  26. Nov 12, 2019 at 12:30 PM
    Rattler3533
    Rattler3533 New Member
    2017 Tundra 1794
    I have a stock 19 TSS Tundra and took my RV up the Hill country in Texas. RPM's were at a steady 2900/3000 is that normal? also mpg was ridiculous 8/9 mpg!! after trip I started to think of trading in for diesel!! but lover my Tundra but the mpg six, I knew getting my Tundra would be a killer of gas but now that I want to travel it's got me thinking of trading in? hoping Toyota comes out in 2021 with a better mpg Tundra..
  27. Nov 12, 2019 at 12:39 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Normal.
    Rattler3533[QUOTED] likes this.
  28. Nov 12, 2019 at 12:40 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    We all drive jacked-up-4x4-heavy-ass-3.5 ton-high-drag low speed-monsters.
    Its not mileage , its yardage.
    Im sorry , but if you can afford a boat or toy hauler trailer and a newer Tundra , you should be able to feed that bitch's 38 gallon guts.
    Yeah , mine sucks too! 12 on the highway is about average.
    Jrharvey02 and Rattler3533 like this.
  29. Nov 12, 2019 at 1:12 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I've saved myself a lot of stress over the years by NEVER calculating mpg.
    Now, I do often calculate my beer temperature.
    Life is a matter of perspective ...
    P.S. Seriously, I used to calculate mpg obsessively. One day I was like, "Why am I doing this?" Make choices. Live with them. Move on.
  30. Nov 12, 2019 at 2:36 PM
    mrkastni
    mrkastni New Member
    Michael
    South Dakota
    2018 Limited CM Blazing Blue
    I have found that pulling my travel trailer (about 5500lbs) causes MPG to be cut in half from unloaded MPG. Across the range of speed, hills, or terrain. It is frequent that I pull the camper to places early, then return home along the same route. This is how I was able to notice the comparison.
    17 empty at 70, 8-9 towing camper is most typical.
